Home » Language IDEs » CDT » Build directory changes every time I open properties
Build directory changes every time I open properties [message #1059601] Mon, 20 May 2013 14:05 Go to next message
Ryan McClelland is currently offline Ryan McClelland
Every time I open the properties for the project, the build directory changes back to the default from what I had set it from. Is there anyway to stop eclipse from changing the build directory back to default every time I open properties?
Re: Build directory changes every time I open properties [message #1059903 is a reply to message #1059601] Wed, 22 May 2013 03:08 Go to previous message
Axel Mueller is currently offline Axel Mueller
That should not happen. Did you exit the property dialog by clicking OK after you changed the directory? Is the directory saved to the file .cproject in your project (note: file is hidden in Project Explorer)?
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:problem by option -openmp of ifort
Next Topic:How to use and modify the AST tutorial
Current Time: Tue May 28 05:45:23 EDT 2013
Powered by FUDForum. Page generated in 0.13078 seconds
