Home » Language IDEs » CDT » problem by option -openmp of ifort
problem by option -openmp of ifort [message #1059483] Sun, 19 May 2013 10:29 Go to next message
milad milad is currently offline milad milad
hi to all user
when use only [ifort ] copmiler all project good working but
when Im use [ ifort -openmp] eclips show error that:
/home/milad/workspace/test3/bin/test3: error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
im set debuge configuration>> debugger>>share libraries>>
then add /opt/intel/composer_xe_2013.1.117/compiler/lib/ia32/
but this not work
Re: problem by option -openmp of ifort [message #1059900 is a reply to message #1059483] Wed, 22 May 2013 03:04 Go to previous message
Axel Mueller is currently offline Axel Mueller
In the Debug Launch Configuration you should add "/opt/intel/composer_xe_2013.1.117/compiler/lib/ia32/" to the environment variable LD_LIBRARY_PATH
  1. Menu Run->Debug configurations...
  2. select your configuration and go to tab "Environment"
  3. click button "Select.."
  4. Select LD_LIBRARY_PATH and then click OK
  5. Edit the variable
  6. append your path (paths are separated by a Smile
If LD_LIBRARY_PATH does not exist yet you can create it.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:the complex problem in my lib*.so
Next Topic:Build directory changes every time I open properties
Current Time: Tue May 28 05:46:05 EDT 2013
Powered by FUDForum. Page generated in 0.07437 seconds
