Home » Eclipse Projects » BIRT » Birt ODA 4.2.2
Birt ODA 4.2.2 [message #1058284] Mon, 13 May 2013 09:05 Go to next message
fabien allemand is currently offline fabien allemand
I would like to know how to migrate birt plugin version 2.6.1 to 4.2.2
Currently, I am able to create this latest version in my eclipse plugins and make a valid test. But I don't know how to generate the plugin for version 4.2.2 Birt Designer. In fact, I generate jar does not allow me to see the specific datasource that I created.
Re: Birt ODA 4.2.2 [message #1058449 is a reply to message #1058284] Tue, 14 May 2013 03:36 Go to previous messageGo to next message
Some details:
I followed this tutorial: www.ibm.com/developerworks/library/ba-birtextpoints/
that works very well. Now I want to use this plugin in a Birt Designer I download. How should I do?
Re: Birt ODA 4.2.2 [message #1058779 is a reply to message #1058449] Tue, 14 May 2013 23:41 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
You should be able to drop the plug-in into your dropins folder in the BIRT download.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Birt ODA 4.2.2 [message #1058847 is a reply to message #1058779] Wed, 15 May 2013 08:04 Go to previous messageGo to next message
Thanks for your answer.
But what do you mean when you say into your dropins folder ?
In Birt, I have a plugin folder but if I drop my jar file (my plugin) into this folder and after a restart of designer, my ODA didn't appear when I create a DataSource.
Re: Birt ODA 4.2.2 [message #1059137 is a reply to message #1058847] Thu, 16 May 2013 20:10 Go to previous messageGo to next message
The plugins folder should work too, but there should be a dropins folder there, too. I have one in my 4.2.2 install.
For your ODA, do you have a designer/UI plugin and a runtime plugin created?
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Birt ODA 4.2.2 [message #1059684 is a reply to message #1059137] Tue, 21 May 2013 04:20 Go to previous messageGo to next message
Yes, we have both plugin for designer and runtime.
I install birt in : birt-rcp-report-designer-4_2_2
and there is this folders : configuration, p2, plugins, and workspace.
I haven't dropins folder.
Re: Birt ODA 4.2.2 [message #1059877 is a reply to message #1059684] Wed, 22 May 2013 01:02 Go to previous message
Ah You're using the RCP. I didn't notice that before if you mentioned it. Like I said before, the plugins folder will work, too. Can you send me your plug-ins? If you cannot post them in here, you can email them to me. mwilliams at actuate dot com
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Dynamic Master page
Next Topic:Multi level Pie Chart
Current Time: Tue May 28 22:29:28 EDT 2013
Powered by FUDForum. Page generated in 0.01632 seconds
