Home » Modeling » GMF (Graphical Modeling Framework) » Auto save Diagram
Auto save Diagram [message #1059492] Sun, 19 May 2013 15:15 Go to next message
bradai hazem is currently offline bradai hazem
I want to auto save my diagram when i exerce any modification(create,modify..)
How can i do this ?
Re: Auto save Diagram [message #1059512 is a reply to message #1059492] Mon, 20 May 2013 04:07 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
You can add a listener to the command stack.
On 19/05/2013 9:15 PM, bradai hazem wrote:
> How can i do this ?
Re: Auto save Diagram [message #1059582 is a reply to message #1059512] Mon, 20 May 2013 11:16 Go to previous messageGo to next message
Thanks bro for your reply.
Can u help me more ? what should i write exactly and in which class ?
Re: Auto save Diagram [message #1059587 is a reply to message #1059582] Mon, 20 May 2013 11:36 Go to previous messageGo to next message
We're not here to do your work for you. For that kind of work someone
pays me. Here you can expect suggestions and if you don't demonstrate
some self initiative in follow up on them, it's unlikely you'll get much
more help.
Re: Auto save Diagram [message #1059665 is a reply to message #1059587] Tue, 21 May 2013 03:03 Go to previous messageGo to next message
if u want help me or let other people make it
Re: Auto save Diagram [message #1059687 is a reply to message #1059665] Tue, 21 May 2013 04:24 Go to previous messageGo to next message
I do nothing to prevent other people from helping you but you should
keep in mind that things such as the lack of capital letters in your
post and also the use of "u" instead of "you" make you look lazy,
stupid, or careless, anyone of which will tend to annoy people. Of
course I and most of the helpful people here on the forums understand
that English is not a native language for everyone so of course we're
all tolerant of errors due to such things, but I know from your other
posts that you know the difference between u and you. So I'd suggest
you read carefully the following information and use that to guide how
best to ask questions that will tend to invite helpful answers:
www.catb.org/esr/faqs/smart-questions.html#intro
Re: Auto save Diagram [message #1059835 is a reply to message #1059687] Tue, 21 May 2013 16:11 Go to previous messageGo to next message
when i post a question in the forum et already paseed days and days searching for solution so don't talk about thing that you didn't know and thank you very much about saying "stupid" i appreciate that from a person say that he want help people
Re: Auto save Diagram [message #1059868 is a reply to message #1059835] Tue, 21 May 2013 23:34 Go to previous message
Bradai,
It's clear you didn't read the information at the link or you'd not have
posted a note like this. I didn't say you are stupid, I said the way
the question is formulated in a fashion that makes you appear to be one
of the following: lazy, stupid, or careless. It's mostly about
appearances, so if you had read carefully the information at the link,
you would have learned how to create an impression that makes you appear
as someone others would want to invest time in helping. Instead, you
create more bad impressions here, i.e., you appear not to be capable of
holding down the shift key while typing the letter "i" so you can
properly spell the word "I". In fact you appear to not know about using
a shift key at all. You also appear not to be able to find the "." to
end a sentence though you appear to be able to find quotation marks and
to spell abbreviations such as "don't" properly. Also it doesn't appear
as if you are able to run a spell checker on your formulation. But all
that is are just the superficial appearances (which creates first
impressions).
Let's consider your claim that you did your days of searching: I go to
my Google search bar in my favorite browser and type "EMF command stack
listener" and low and behold, I find Javadoc for a command stack
listener. Even searching for your original question "GMF autosave" I
find http://www.eclipse.org/forums/index.php/m/490094/. To me that
makes your claim of having spent days seem less than credible.
Previous Topic:Defining elements to draw from the ecore metamodel
Next Topic:Remove bottom padding from rectangle
Current Time: Tue May 28 13:33:07 EDT 2013
Powered by FUDForum. Page generated in 0.03076 seconds
