| Debug support for DSL in Xtext [message #555713] |
Fri, 27 August 2010 14:53  |
No real name Messages: 101 Registered: August 2010 |
I'm a new user of a Xtext/Eclipse. I'm reading through the documentation. I'm interested in creating a small domain-specific language. Let's say I defined my language and write a code generator for this with Xtext. For example, say 1 line in my DSL executes 10 lines of C/C++ code. I can use the existing C/C++ development tools for building/running/debugging the generated code.
My question is regarding debugging - single stepping through my DSL. Since the generator is generating C/C++ code, I can single step that in gdb. However, is it possible or is thre an interface where I can do the following.
1. I put a break point in my DSL. I say single-step. That executes the 10 lines of code and then moves the cursor position down do the next line and stops.
Thus, I want to single step through my DSL and not the generated code. Is there some way to do this in Etext/Eclipse?
Thank you for any pointers/help.
[Updated on: Fri, 27 August 2010 14:55] Report message to a moderator
| Re: Debug support for DSL in Xtext [message #1059859 is a reply to message #555713] |
Tue, 21 May 2013 20:36  |
April Dai Messages: 2 Registered: April 2013 |
Junior Member |
We are facing the same issue, we have defined a dsl, and it is getting translated to a legacy language, would like to provide debugging support, but the execution of one line in dsl may result in multiple lines in the legacy code...
Were you able to find a solution for your problem?
FUDForum. Page generated in 0.02038 seconds
