Home » Newcomers » Newcomers » java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin(Something missing in my plugin?)
java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #1058087] Fri, 10 May 2013 17:44 Go to next message
Robert Smith is currently offline Robert Smith
Hi all,
I hope you can help, I'm at the end of my rope. I am writing a very simple headless plugin (extending org.eclipse.core.runtime.applications). The sole purpose of this plugin is import existing sample projects into Eclipse from the command line.
I know that there is a plugin in cdt which already does this. However, this is part of an installer, so can not be allowed to fail and pop up any dialogs.
The relevant code in my IApplication's start() method is:
try
System.out.println("In try block");
description = ResourcesPlugin.getWorkspace().loadProjectDescription(new Path(projectName + "/.project"));
IProject project = ResourcesPlugin.getWorkspace().getRoot().getProject(description.getName());
project.create(description, null);
project.open(null);
System.out.println("Done.");
catch (CoreException e)
Here is my manifest:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Intel Headless Utilities
Bundle-SymbolicName: com.intel.eclipse.headless;singleton:=true
Bundle-Version: 1.0.0.0
Bundle-Activator: com.intel.eclipse.headless.Activator
Bundle-Vendor: Intel
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.core.resources
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Bundle-ActivationPolicy: lazy
Note that I have declared a dependency on "org.eclipse.core.resources". Here is the plugin.xml:
<?eclipse version="3.4"?>
<plugin>
<extension
id="import"
point="org.eclipse.core.runtime.applications">
<application
cardinality="singleton-global"
thread="main"
visible="true">
<run
class="com.xxx.eclipse.headless.Import">
</run>
</application>
</extension>
</plugin>
When I try to run this using "eclipse -consoleLog -data C:\Android\eclipse\workspace -noSplash -application com.xxx.eclipse.headless.import -project C:\Android\eclipse\workspace\helloworld", I get the following error:
!SESSION 2013-05-10 14:11:36.598 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=1.7.0_21
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application com.xxx.eclipse.headless.import -import C:/Android/eclipse/workspace/helloworld
Command-line arguments: -data C:\Android\eclipse\workspace -application com.xxx.eclipse.headless.import -import C:/Android/eclipse/workspace/helloworld
!ENTRY org.eclipse.osgi 4 0 2013-05-10 14:11:38.508
!MESSAGE Application error
!STACK 1
at com.xxx.eclipse.headless.Import.importProject(Import.java:97)
at com.xxx.eclipse.headless.Import.start(Import.java:60)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.resources.ResourcesPlugin
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 15 more
I don't understand what the problem could be. I have declared the dependency correctly. What am I missing?
Many thanks,
Robert
Re: java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #1058124 is a reply to message #1058087] Sun, 12 May 2013 02:05 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
It might just be the forum software messing with indentation, but when you open the manifest file in the PDE Manifest Editor, is the resources plug-in still listed among the dependencies?
Nitin Dahyabhai
Eclipse WTP, IBM
Re: java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #1058915 is a reply to message #1058124] Wed, 15 May 2013 14:04 Go to previous messageGo to next message
Yes, the plugin is listed in the manifest editor. Sorry for the bad formatting.
Re: java.lang.NoClassDefFoundError: org/eclipse/core/resources/ResourcesPlugin [message #1059764 is a reply to message #1058915] Tue, 21 May 2013 10:32 Go to previous message
Are there more exceptions and errors further down?
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Eclipse
Next Topic:Any help plz
Current Time: Tue May 28 04:36:56 EDT 2013
Powered by FUDForum. Page generated in 0.01878 seconds
