Home » Modeling » Papyrus » Java Code Generation(Having Trouble Installing Java Code Generation Extension)
Java Code Generation [message #1059491] Sun, 19 May 2013 15:11 Go to next message
David Hetherington is currently offline David Hetherington
I am new to Papyrus and am just learning to use the tool. I am now working my way through the tutorials and found the nice videos of using the Java Code generator here:
<link deleted because Forum software does not like links>
Very nice. I would like to try to use it.
So...I then backed up and followed the instructions to add the update site for Papyrus:
This seemed to work fine. I could see a number of extensions including three kinds of code generation. I selected Java and tried to install and got the error message shown in the attached PNG file:
"Missing requirement: Java code generator for Papyrus 1.3.3.200911231214 (com.cea.papyrus.gen.java.feature.group 1.3.3.200911231214) requires 'com.cea.papyrus.feature.feature.group 1.9.0' but it could not be found"
I also tried to install "Required Dependency" and got this error message:
"Missing requirement: Acceleo integration plugin for Papyrus 1.2.0 (com.cea.papyrus.integration.acceleo.feature.group 1.2.0) requires 'com.cea.papyrus.feature.feature.group 1.9.0' but it could not be found"
This also seems a bit odd because Papayrus itself seems to be at 0.9.2
David Hetherington
David Hetherington
Re: Java Code Generation [message #1059734 is a reply to message #1059491] Tue, 21 May 2013 09:01 Go to previous messageGo to next message
Camille Letavernier is currently offline Camille Letavernier
Hi David,
Everything from papyrusuml.org/Papyrus 1.12 is deprecated and unmaintained (For about 4 years now), since Papyrus has migrated and is now an Eclipse Project: http://www.eclipse.org/papyrus
I think the Java code generation plug-ins will be back in Papyrus 0.10, in June 2013 (Eclipse Kepler).
Camille
Re: Java Code Generation [message #1059741 is a reply to message #1059491] Tue, 21 May 2013 09:15 Go to previous message
What do you want to generate?
Basic Java class structure: use UML2Ecore and the EMF code generator.
Basic Java class structure and behaviour: use UML2Ecore and the EMF code
generator extended by the OCL code generator.
State machines etc - no support yet.
Non Java - no support yet.
Ed Willink
> David Hetherington
Previous Topic:Where are the Tabbed Property View extensions are defined?
Next Topic:EMF transaction for inserting a new Element in a diagram
Current Time: Tue May 28 16:42:44 EDT 2013
Powered by FUDForum. Page generated in 0.01613 seconds
