| Re: How to extract the complete source code, not only the signatures [message #1059781 is a reply to message #1059763] |
Tue, 21 May 2013 10:54   |
Hugo Bruneliere Messages: 470 Registered: July 2009 |
The actual name of the parameter is DEEP_ANALYSIS.
For passing such as parameter, you should take a look to the API from the org.eclipse.modisco.infra.discovery.core/org.eclipse.modisco.infra.discovery.core plugins (and also the org.eclipse.modisco.java.discoverer plugin for the Java model discoverer implementation).
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
| Re: How to extract the complete source code, not only the signatures [message #1059888 is a reply to message #1059828] |
Wed, 22 May 2013 02:41  |
Unfortunately, deep analysis is not currently supported from .class files (only from sources).
The LibraryReader class used by the DiscoverJavaModelFromLibrary class stays at the type and member level.
However, for possible future enhancements, you can propose a feature request by submitting a MoDisco bug onto the Eclipse Bugzilla (and you may even attach a corresponding patch).
Nantes - France
FUDForum. Page generated in 0.01793 seconds
