Home » Modeling » M2T (model-to-text transformation) » What is genBuildAcceleo
What is genBuildAcceleo [message #1059599] Mon, 20 May 2013 13:38
HI
Using M7 I see a new kind of Acceleo error.
What is genBuildAcceleo ?
Has an API changed?
org.eclipse.acceleo.engine.AcceleoEvaluationException: Could not find
public template genBuildAcceleo in module buildAcceleo.
org.eclipse.acceleo.engine.service.AcceleoService.findTemplates(AcceleoService.java:1099)
org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:425)
org.eclipse.acceleo.internal.ide.ui.generators.AcceleoUIGenerator.generate(AcceleoUIGenerator.java:479)
org.eclipse.acceleo.internal.ide.ui.generators.AcceleoUIGenerator.generateBuildAcceleo(AcceleoUIGenerator.java:223)
org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.generateAcceleoBuildFile(AcceleoBuilder.java:630)
org.eclipse.acceleo.internal.ide.ui.builders.AcceleoBuilder.build(AcceleoBuilder.java:245)
org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:726)
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
Ed Willink
Previous Topic:[Acceleo] Referencing xsd-based metamodel for java services
Next Topic:[Acceleo] Problem when generating methods with the same name
Current Time: Tue May 28 14:47:08 EDT 2013
Powered by FUDForum. Page generated in 0.02404 seconds
