Home » Modeling » ATL » How to execute ATL Transformation without using eclipse
How to execute ATL Transformation without using eclipse [message #1037988] Wed, 10 April 2013 04:56 Go to next message
rourou S is currently offline rourou S
I want to know if there is a way to execute ATL transformation without using eclipse.
Best Regards.
Re: How to execute ATL Transformation without using eclipse [message #1039001 is a reply to message #1037988] Thu, 11 April 2013 11:51 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
Some experiments have been performed on providing a standalone version of ATL (considering its version 3.2) including notably a small ATL command line.
It is currently only available from http://docatlanmod.emn.fr/ATL/ATLStandaloneJAR.zip and not part of the official project releases.
Please, don't hesitate to contact Sagar Sen who has implemented this standalone component if you need complementary information.
I hope this helps.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: How to execute ATL Transformation without using eclipse [message #1059571 is a reply to message #1039001] Mon, 20 May 2013 10:10 Go to previous message
Thanks a lot for your answer Hugo. I tested the ATL standalone Jar but I thing that it does not manage Ecore file with imported libraries like UML meta Model and its PrimitiveType Library. ("pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"). I get some errors due to this point.
Best Regards,
Rourou
Previous Topic:ATL
Next Topic:toString helper
Current Time: Tue May 28 09:24:16 EDT 2013
Powered by FUDForum. Page generated in 0.01943 seconds
