Home » Modeling » EMF » [CDO] We are trying to get CDO running on Oracle 11g(But struggling with this error!)
[CDO] We are trying to get CDO running on Oracle 11g [message #1053689] Tue, 07 May 2013 04:50 Go to next message
Børre  ordbakken is currently offline Børre ordbakken
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] CREATE TABLE cdo_lobs (id VARCHAR2(64), size NUMBER, bdata BLOB, cdata CLOB)
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] -- ORA-00904: : ugyldig identifikator
jvm 1 |
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: Error in WrapperListener.start callback. org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:447)
I'm using the code from emf-cdo-S20130319-1538 build
Is there some way to make Oracle less sensitive ?
Or is there still some problemes with the OracleAdpater ?
Børre Nordbakken
Brønnøysundregistrene
Re: [CDO] We are trying to get CDO running on Oracle 11g [message #1053808 is a reply to message #1053689] Tue, 07 May 2013 12:31 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal Karaca
The 'size' column should have been renamed to 'lsize' which is not in your case.
AFAIK, that bug was fixed 6 months ago. Are you sure you are using the version you have mentioned?
Børre ordbakken wrote on Tue, 07 May 2013 10:50
jvm 1 |
Børre Nordbakken
Re: [CDO] We are trying to get CDO running on Oracle 11g [message #1053833 is a reply to message #1053689] Tue, 07 May 2013 15:22 Go to previous messageGo to next message
Hi!
Isn't this one the latest ? org.eclipse.net4j.db.oracle_1.0.0.v20130316-1201.jar
Found inside emf-cdo-S20130319-1538-Dropins.zip
Børre Nordbakken
Re: [CDO] We are trying to get CDO running on Oracle 11g [message #1053836 is a reply to message #1053833] Tue, 07 May 2013 15:37 Go to previous messageGo to next message
Can you provide/check the output of the osgi command "ss" in your running cdo server's console?
(You can turn the osgi console on by providing the -console parameter when running the server.)
Børre ordbakken wrote on Tue, 07 May 2013 21:22
Hi!
Børre Nordbakken
Re: [CDO] We are trying to get CDO running on Oracle 11g [message #1053838 is a reply to message #1053689] Tue, 07 May 2013 15:40 Go to previous messageGo to next message
Hi!
I'm not running the CDO server inside a OSGi container.
Have build my "own" server. And using a JavaWrapper to launch the server.
Børre
Re: [CDO] We are trying to get CDO running on Oracle 11g [message #1059537 is a reply to message #1053833] Mon, 20 May 2013 07:22 Go to previous message
Eike Stepper is currently offline Eike Stepper
Am 07.05.2013 21:22, schrieb Børre ordbakken:
> Hi!
Sorry for the late reply. Please check the version of your cdo.server.db bundle. It's the one that hardcodes the column
names of the system tables.
Cheers
/Eike
http://www.esc-net.de
> Best regards,
> Børre Nordbakken
Previous Topic:Help with Transactional Editing Domain and Modal Dialogs
Next Topic:[CDO 4.2] ConcurrentModificationException in native with EAllContents() while not in legacy
Current Time: Tue May 28 11:42:13 EDT 2013
Powered by FUDForum. Page generated in 0.02325 seconds
