| Re: Eclipse include folder not working [message #1059478 is a reply to message #1059442] |
Sun, 19 May 2013 08:09   |
Axel Mueller Messages: 1829 Registered: July 2009 |
James Mising name wrote on Sat, 18 May 2013 17:12Ok, I am done with Eclipse. It is clearly broken is several key areas and no one can ever convince me otherwise. I refer, of course, to the attached image. I dare someone to explain that one.
That's rather easy. You entered a path where the linker wants a library name.
BTW, you should be less hostile if you want more helpful answers.
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
| Re: Eclipse include folder not working [message #1059502 is a reply to message #1059497] |
Mon, 20 May 2013 00:51  |
Nobody Mising name Messages: 65 Registered: July 2010 |
Member |
James Mising name wrote on Sun, 19 May 2013 19:52I went back to just using makefiles. Eclipse is working now as an editor/gdb front. I'll keep managing my own makefiles outside of Eclipse and everything should be fine.
Exactly the same for me, Eclipse CDT internal build system is a joke, not usable for everything except hello world projects.
FUDForum. Page generated in 0.01658 seconds
