Home » Modeling » Papyrus » Where are the Tabbed Property View extensions are defined?
Where are the Tabbed Property View extensions are defined? [message #1058262] Mon, 13 May 2013 08:06 Go to next message
Emre Taspolatoglu is currently offline Emre Taspolatoglu
Hello there, I need to implement a plug-in which defines a specific tabbed property view for some dynamic instances (based on EMF models) and contribute it to the Eclipse's standard Properties View.
For that matter, I wanted to look into how Papyrus does that, since it has a great tabbed properties view support for the dynamic instances (e.g. UML Stereotypes). But I couldn't find the package where these tabbed properties view extensions are defined.
Since the contributor to the Eclipse Properties View is the PapyrusMultiDiagramEditor, I first looked into the org.eclipse.papyrus.editor. But there weren't any extension definitions for the tabs and sections. And further search for the section definitions was unfortunately no success.
I would be very glad, if you could point me to the right place, where the property sections are defined and which plug-in is extending the Tabbed Properties View.
Thank you very much!
Re: Where are the Tabbed Property View extensions are defined? [message #1059482 is a reply to message #1058262] Sun, 19 May 2013 10:09 Go to previous message
Goood Guy is currently offline Goood Guy
Member
http://www.eclipse.org/forums/index.php/m/962694/ may help you.
Previous Topic:Update of PapyrusPalettePreferences?
Next Topic:Java Code Generation
Current Time: Tue May 28 16:43:06 EDT 2013
Powered by FUDForum. Page generated in 0.01672 seconds
