Home » Modeling » OCL » How to specify integer value in an invariant?
How to specify integer value in an invariant? [message #1058337] Mon, 13 May 2013 11:23 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Lets take this example:
Constraint invariant = helper.createInvariant("self.Modules->size()<=20")
How to give 20 as integer?
In here, it takes as string, and i get an error:
Exception in thread "main" java.lang.AbstractMethodError: org.eclipse.ocl.ecore.impl.IntegerLiteralExpImpl.setLongSymbol(Ljava/lang/Long;)V
Re: How to specify integer value in an invariant? [message #1059414 is a reply to message #1058337] Sat, 18 May 2013 01:57 Go to previous messageGo to next message
Abbas Mansoori Razi is currently offline Abbas Mansoori Razi
hi
you must use AbstractVisitor in order walking ocl AST
and override visitOperationCallExp method,and useing getIntegerSymbol() such as follow:
List<OCLExpression<EClassifier>> arguments = callExp.getArgument();
if (arguments.isEmpty()) {
argumentResults = Collections.emptyList();
} else {
argumentResults = new java.util.ArrayList<Boolean>(arguments.size());
System.out.printf( arguments.toString());
for (OCLExpression<EClassifier> qual : arguments) {
if(qual instanceof IntegerLiteralExp)
valProperty=((IntegerLiteralExp) qual).getIntegerSymbol();
argumentResults.add(safeVisit(qual));
Abbas Mansoori Razi
Re: How to specify integer value in an invariant? [message #1059436 is a reply to message #1059414] Sat, 18 May 2013 07:40 Go to previous message
The original question made no sense to me, so perhaps I'm not surprised
that the answer doesn't either.
Ed Willink
On 18/05/2013 06:57, Abbas Mansoori Razi wrote:
> hi
> } else {
> qual : arguments) {
> Regards
> Abbas Mansoori Razi
Previous Topic:line1 : error missing EOF at '('
Next Topic:Custom validation failure messages
Current Time: Tue May 28 16:15:31 EDT 2013
Powered by FUDForum. Page generated in 0.01702 seconds
