Home » Modeling » GMF (Graphical Modeling Framework) » EVL constraints
EVL constraints [message #1059034] Thu, 16 May 2013 07:06 Go to next message
serhat gezgin is currently offline serhat gezgin
Hi all,
When i write this validation to my model;
	constraint doldur {
		guard : self.satisfies('IllegalCharactersForName')
		check {
			if(self.ownedField.select(f | f.name = "Text").size() <> 1){
				var text = new TextField;
				text.name = "Text";
				text.displayName = "Text";
				self.ownedField.add(text);
			if(self.ownedField.excludes(text)){
					return false;
			return true;
		message : 'laaaa'
i always get error (atached picture and txt file shows error)
But i need to create element from validation so how can i do this
anyone can help me ?
  • Attachment: EVLError.png
    (Size: 222.71KB, Downloaded 7 times)
  • Attachment: EVLError.txt
    (Size: 17.02KB, Downloaded 7 times)
[Updated on: Thu, 16 May 2013 07:08]
Report message to a moderator
Re: EVL constraints [message #1059421 is a reply to message #1059034] Sat, 18 May 2013 04:44 Go to previous message
Ralph Gerbig is currently offline Ralph Gerbig
the check constraint of an EVL expression is there to check the model element as it is. I think what you should do is to offer a quick fix via evl. Maybe there you do not have a read only transaction.
Ralph
Previous Topic:Open diagram
Next Topic:Name of deleted Node
Current Time: Tue May 28 13:35:20 EDT 2013
Powered by FUDForum. Page generated in 0.06030 seconds
