Home » Modeling » EMF » CDO model evolution strategy(Looking for thoughts on our proposed model evolution strategy.)
CDO model evolution strategy [message #1058896] Wed, 15 May 2013 11:09 Go to next message
Kyle B is currently offline Kyle B
We are currently in the process of migrating our application to use the CDO framework. For the past few weeks I have been investigating how to handle model evolution.
Our meta-models change very frequently so it would be safe to say we will need to evolve the CDO model with each version upgrade. I have investigated some of the suggestions others have posted on this forum, but none seem to fit our needs (backup/restore, copy plugin with new nsuri, dump sql).
The approach I have been investigating involves executing SQL commands to the database to update the table structures and updating the CDO meta-model tables to reflect the new changes. The model changes will either be detected using EMF compare, or having a method where the developers will describe the changes manually.
I have manually tested this approach with several different types of model changes and have been successful so far, I was wondering if anyone more experienced with CDO might be able to foresee a pitfall?
Thank you,
Kyle
Re: CDO model evolution strategy [message #1058979 is a reply to message #1058896] Thu, 16 May 2013 02:42 Go to previous messageGo to next message
Per Sterner is currently offline Per Sterner
Member
We are also in the same situation. Until now, we could reimport the data from the old storage.
I am also interested in the the SQL-command migratioen implementation. I have only tried to migrate a Eclass movement to another EPackage. There I only changed the column 'cdo_class' in the 'cdo_objects' Table. Although I thought it would be nice, if the cdo_class in that table would only be a reference Smile
I am also interested if there are pitfalls. And perhaps we should cooperate with this migration functionality, so that a lot migration-cases are covered.
Per Sterner
Re: CDO model evolution strategy [message #1059277 is a reply to message #1058979] Thu, 16 May 2013 16:00 Go to previous messageGo to next message
Christophe Bouhier is currently offline Christophe Bouhier
It's more and more obvious many are looking for a solution for this.
From Eike, I understand he wants to do it, if only properly funded. But
this is is tricky for various (Including myself) in monetary terms, but
I can donate coding time. We will obviously need Eike's mentoring. (I am
pretty sure, he knows how to attack this problem).
I have started to look into it myself, my approach is to produce a diff
of the meta models, and use the diff to migrate the data. I don't want
to do it SQL based, as the CDO logic, needs to be in the loop I believe.
(This is very much from the gut..hehe) . I have studied the
export/import to XML code, which is some sort of middle ground between
the CDO API, and SQL. I have started to experiment emulating the
export/import behavior and applying the diffs, but no where near a real
solution...
Eike, would you be willing to mentor a solution, which would make it in
CDO 4.4? (I followed your discussions rgd PDE and fragments for 4.3...so
you must be other things on your mind!).
Cheers Christophe
On 16-05-13 08:42, Per Sterner wrote:
> would only be a reference :)
> Per Sterner
[CDO] Re: CDO model evolution strategy [message #1059398 is a reply to message #1059277] Fri, 17 May 2013 18:19 Go to previous messageGo to next message
Warwick Burrows is currently offline Warwick Burrows
Member
Guys, this thread may not come to Eike's attention without [CDO] in the title. He did tell me once that I should have added that to the title of a post to this forum. I'll update the title in my reply just in case.
Oh and I'm also interested in a model evolution strategy as we've gone to production with CDO but have managed to avoid model changes up to this point. That won't last for long.
Warwick
Re: [CDO] Re: CDO model evolution strategy [message #1059416 is a reply to message #1059398] Sat, 18 May 2013 02:06 Go to previous message
Eike Stepper is currently offline Eike Stepper
Am 18.05.2013 00:19, schrieb Warwick Burrows:
Thank you, but I have notice it before. I have a Thunderbird filter that highlights all posts with CDO or Net4j in the
subject ;-)
These days I'm very busy with preparing next month's release and this particular subject (model evolution support) has
been discussed a lot already. It's definitely on my wish list for 4.3.
Cheers
/Eike
http://www.esc-net.de
> Warwick
Previous Topic:[CDO] revisions or versions list.
Next Topic:Xcore and contains of referenced model
Current Time: Tue May 28 11:43:30 EDT 2013
Powered by FUDForum. Page generated in 0.01903 seconds
