Home » Modeling » EMF » [CDO] To know if a Resource is being modified by others
icon5.gif  [CDO] To know if a Resource is being modified by others [message #1059179] Fri, 17 May 2013 03:07 Go to next message
Marc Gil is currently offline Marc Gil
Member
Is it possible to know if a Resource is being edited or modified by other users? Not read/write locked but being edited in a normal way, for instance via CDO Editor or others.
Marc
Re: [CDO] To know if a Resource is being modified by others [message #1059183 is a reply to message #1059179] Fri, 17 May 2013 03:35 Go to previous messageGo to next message
Member
I can access to the list of remote sessions, but I think I can't inspect the list of views or transactions opened by these sessions...
resourceNode.cdoView().getSession().getRemoteSessionManager().getRemoteSessions()
Marc
Re: [CDO] To know if a Resource is being modified by others [message #1059278 is a reply to message #1059179] Fri, 17 May 2013 03:21 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 17.05.2013 09:07, schrieb Marc Gil:
No, the server and, hence, other clients are only notified about commits and lock changes, not all getter or setter
calls that happen in a local transaction.
You can either implement your own Net4j SignalProtocol (see examples) or use
CDORemoteSessionManager.sendMessage(CDORemoteSessionMessage, CDORemoteSession...). The CDORemoteSessionManager is
accessible via CDOSession.getRemoteSessionManager().
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] To know if a Resource is being modified by others [message #1059279 is a reply to message #1059183] Fri, 17 May 2013 03:41 Go to previous messageGo to next message
Am 17.05.2013 09:35, schrieb Marc Gil:
> these sessions...
No, that's not possible. Neither could you determine complex information such as remote object dirty state.
You need to use sendMessage() to implement your own protocol. I.e., when something happens locally that other remote
sessions might be interested in you need to:
1) detect it (normally with an IListener) and
2) send it to the remote sessions (where the message can be handled appropriately),
Cheers
/Eike
Re: [CDO] To know if a Resource is being modified by others [message #1059356 is a reply to message #1059279] Fri, 17 May 2013 11:49 Go to previous messageGo to next message
Member
Thanks Eike,
Finally I solved it using IListeners, and when a commit happens I do what I need.
The scenario is the following:
- User A has the resourceNode X opened, for instance, with the CDO Editor.
- User B tries to rename or delete the resourceNode X.
I wanted that User B receives an alert indicating there are users that has this resource opened, in order to prevent some errors. One solution is that A has opened the resourceNode in lock mode, so B could not rename it. Another solution is that B renames the resource, and then A receives a message alerting that the editor is going to be closed. Of course, all the non saved changes will be lost... I have implemented both of them.
Marc
Re: [CDO] To know if a Resource is being modified by others [message #1059365 is a reply to message #1059356] Fri, 17 May 2013 12:34 Go to previous messageGo to next message
Am 17.05.2013 17:49, schrieb Marc Gil:
> Thanks Eike,
+1
Why doesn't the receiving editor just handle the rename such that it can stay open?
Cheers
/Eike
Re: [CDO] To know if a Resource is being modified by others [message #1059366 is a reply to message #1059365] Fri, 17 May 2013 12:41 Go to previous message
Member
Let me to say that my editor is not as "easy" as the default cdo editor was Razz And at this moment, I have no time to manage this solution, but I have annotated it and when I can include your solution I will implement it Smile
Thanks Eike!
Marc
Previous Topic:EMF Languge Pack do not work
Next Topic:Change EMF properties and refresh Property View
Current Time: Tue May 28 11:45:11 EDT 2013
Powered by FUDForum. Page generated in 0.01778 seconds
