Home » Modeling » Papyrus » (Programmatically) auto-generate Class-Diagram from existing UML-Model
(Programmatically) auto-generate Class-Diagram from existing UML-Model [message #901954] Wed, 15 August 2012 05:52 Go to next message
Simon Hrak is currently offline Simon Hrak
Hey,
i used xtext and xtend to generate a .uml Class-Model from sourcecode. The next step should be to generate a graphical papyrus class diagram.
Is there any approach to automatically generate a class-diagram (programmatically)?
Thank you Razz ,
Simon
Re: (Programmatically) auto-generate Class-Diagram from existing UML-Model [message #901961 is a reply to message #901954] Wed, 15 August 2012 06:34 Go to previous messageGo to next message
Papyrus can generate a diagram from UML using the New->... functionality.
You could invoke the underlying functionality programmatically and
perhaps influence the layout to suit your purposes.
Ed Willink
On 15/08/2012 10:52, Simon Hrak wrote:
> Hey,
> (programmatically)?
> Thank you :p ,
> Simon
Re: (Programmatically) auto-generate Class-Diagram from existing UML-Model [message #907133 is a reply to message #901961] Mon, 03 September 2012 07:03 Go to previous messageGo to next message
could you give me a little approach on how to "invoke the underlying functionality programmatically"?
Simon
Re: (Programmatically) auto-generate Class-Diagram from existing UML-Model [message #1024074 is a reply to message #907133] Mon, 25 March 2013 15:34 Go to previous messageGo to next message
Michael Gärtner is currently offline Michael Gärtner
Hi Simon
Did you get some answer. I am also interested it the solution.
I have a similar issue to solve.
Thanks!
regards
Michael
Re: (Programmatically) auto-generate Class-Diagram from existing UML-Model [message #1059337 is a reply to message #901954] Fri, 17 May 2013 10:37 Go to previous messageGo to next message
Junfeng Zhao is currently offline Junfeng Zhao
I have the same confusion too now. I want to know if you have found a way to resolve the problem. thanks!
Re: (Programmatically) auto-generate Class-Diagram from existing UML-Model [message #1059340 is a reply to message #1059337] Fri, 17 May 2013 10:53 Go to previous message
Until today I can not solve it. I tried to recreate the steps from the Wizard, but without success.
regards.
Michael
Previous Topic:Initialize papyrus diagram from an UML file
Next Topic:Update of PapyrusPalettePreferences?
Current Time: Tue May 28 16:44:12 EDT 2013
Powered by FUDForum. Page generated in 0.01862 seconds
