| Re: Initialize papyrus diagram from an UML file [message #843902 is a reply to message #843598] |
Fri, 13 April 2012 09:33   |
Federico Toledo Messages: 74 Registered: April 2012 Location: Ciudad Real, Spain |
Member |
ah ok, thank you
but... I didn't consider UML2Tools because it is discontinued, isn't it?
I continued trying and I found a workaround:
If you are in the package explorer and select your UML file, and right-click it, go to new -> Papyrus Model. Select UML, and in my case I want to work with class diagrams.
After that, the new .di is open, and you can go to Model Explorer view, and there you have all the elements of the UML model. As I told you I want to work with class diagrams, so I created one, and then DnD classes to it.
I am still testing it ... but it seems that it works.
I am using the night build of a couple of days ago
Hope it helps, and I hope it works every day even better
| Re: Initialize papyrus diagram from an UML file [message #844714 is a reply to message #843902] |
Sat, 14 April 2012 05:09   |
Yugi Muto Messages: 28 Registered: February 2012 |
Junior Member |
I don't know if it is discontinued (my UML2 Tools version is 0.10.0 from 2011 so it is not so old) but it's true that some features like the "reply message" in the "sequence diagram" are not supported yet... This feature works on Papyrus and Topcased, so UML2 Tools has some important missing features... So we can suppose that UML2 Tools is discontinued...
I follow your instructions and it's true we can see in the Model Explorer view, all the elements of the UML Model. But I can't Drag and Drop the elements in the diagram because the window is grey... This window should be white to be allowed to DnD into it...
Anyway thank you for this tip, maybe it can help to find a correct solution.
[Updated on: Sat, 14 April 2012 05:10] Report message to a moderator
| Re: Initialize papyrus diagram from an UML file [message #1059313 is a reply to message #1059177] |
Fri, 17 May 2013 09:35  |
Junfeng Zhao Messages: 6 Registered: April 2013 |
Junior Member |
Thank for your reply. There exist six command in the filters shortcut menu, including three commands related to connector label and the other three related to content and compartment. the configuration to these options is nothing to do with the problem mentioned before. I wonder whether the need mentioned before by me could be realized by papyrus.
FUDForum. Page generated in 0.02028 seconds
