| Properties of ecore classes [message #1059212] |
Fri, 17 May 2013 06:42  |
Adnan AL-SOSWA Messages: 21 Registered: May 2010 |
Junior Member |
Hi modelers ,
I am beginner in modeling and modeling transformation ,Working with ecore.ecore trying to do some transformation using xpand language ,I could naviagte and access elements of ecore using eclass , eallattributes , eallreferences ,ealloperations ....etc Syntax ,the question is when I click on any eclass , I have some properties that are not part of the structure of eclass , like abstract , default value , supertype ....etc attached picture to show what I mean, is there any code in xpand can enumerate these properties so I can keep all information in the transformation process.
Thanks in advance.
[Updated on: Fri, 17 May 2013 06:43] Report message to a moderator
| Re: Properties of ecore classes [message #1059250 is a reply to message #1059212] |
Fri, 17 May 2013 07:04   |
Ed Willink Messages: 3191 Registered: July 2009 |
You need to look a little harder. Everything you list is part of the
structure of an EClass. What makes you think it isn't?
Ed Willink
On 17/05/2013 11:42, Adnan AL-SOSWA wrote:
> Hi modlers ,
> Thanks in advance.
FUDForum. Page generated in 0.01653 seconds
