Home » Modeling » Graphiti » Property View - Unhandled event loop exception
Property View - Unhandled event loop exception [message #1032039] Tue, 02 April 2013 09:52 Go to next message
Dan Simkins is currently offline Dan Simkins
Member
I have a number of nodes on the canvas, each with a textual name. I have implemented a property section as per tutorial that extends GFPropertySection and implements ITabbedPropertyConstants.
If I select a node on the canvas and display the property view, I can edit the textual name. If I select another node on the canvas, the 'name' field for this other node is shown correctly in the property view, however, if I click in the 'name' field, I get the exception shown below.
I have established that after selecting the second node, if I click on the property 'tab', this activates the property view and I do not see the error.
I have also established that this same behaviour is exhibited in the graphiti tutorial; adding two classes to the canvas and clicking between them with the property view open, when attempting to click in the name field, the exception is thrown.
I would appreciate any assistance in understanding the behaviour and pointers to a resolution.
Many thanks
Dan
Graphiti Version: 0.9.2.v20130211-0913
Error
Tue Apr 02 14:10:44 BST 2013
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTError: Item not added
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:88)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:318)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:332)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:630)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activateBranch(EclipseContext.java:635)
at org.eclipse.e4.ui.internal.workbench.PartActivationHistory.activate(PartActivationHistory.java:52)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:561)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:532)
at org.eclipse.e4.ui.internal.workbench.swt.AbstractPartRenderer.activate(AbstractPartRenderer.java:105)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer$1.handleEvent(ContributedPartRenderer.java:61)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:1447)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:2328)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4572)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4989)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable.java:80)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:2440)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:260)
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2570)
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:3129)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3753)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.swt.SWTError: Item not added
at org.eclipse.swt.SWT.error(SWT.java:4387)
at org.eclipse.swt.SWT.error(SWT.java:4276)
at org.eclipse.swt.SWT.error(SWT.java:4247)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.ToolBar.createItem(ToolBar.java:392)
at org.eclipse.swt.widgets.ToolItem.<init>(ToolItem.java:128)
at org.eclipse.jface.action.Separator.fill(Separator.java:67)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.ui.internal.EditorActionBars.setVisible(EditorActionBars.java:478)
at org.eclipse.ui.internal.EditorActionBars.setActive(EditorActionBars.java:375)
at org.eclipse.ui.internal.EditorActionBars.deactivate(EditorActionBars.java:154)
at org.eclipse.ui.internal.PartSite.deactivateActionBars(PartSite.java:588)
at org.eclipse.ui.internal.EditorSite.deactivateActionBars(EditorSite.java:81)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.deactivateActionBars(CompatibilityPart.java:368)
at org.eclipse.ui.internal.WorkbenchPage$E4PartListener.partDeactivated(WorkbenchPage.java:186)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$3.run(PartServiceImpl.java:205)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.firePartDeactivated(PartServiceImpl.java:203)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.setPart(PartServiceImpl.java:160)
at sun.reflect.GeneratedMethodAccessor20.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 143 more
Re: Property View - Unhandled event loop exception [message #1038072 is a reply to message #1032039] Wed, 10 April 2013 07:12 Go to previous messageGo to next message
Member
For any interested parties, it appears that this may related to machine specific SWT issues as further detailed in the following:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=371245
https://bugs.eclipse.org/bugs/show_bug.cgi?id=375964
https://bugs.eclipse.org/bugs/show_bug.cgi?id=287508
http://blogs.msdn.com/b/alejacma/archive/2009/08/11/controls-won-t-get-resized-once-the-nesting-hierarchy-of-windows-exceeds-a-certain-depth-x64.aspx?PageIndex=1#comments
I shall post an update once I have investigated further.
Dan
Re: Property View - Unhandled event loop exception [message #1059126 is a reply to message #1038072] Thu, 16 May 2013 16:57 Go to previous messageGo to next message
Najd Mourad is currently offline Najd Mourad
i have ceated a graphical editor and tried to synchronize the editing text label with its own property view (as it is described in tutorial) but it did not work. After selecting I get just an error :Contributor MyDiagram.PropertyContributor cannot be created.
Mourad
Re: Property View - Unhandled event loop exception [message #1059311 is a reply to message #1059126] Fri, 17 May 2013 09:33 Go to previous message
Michael Wenz is currently offline Michael Wenz
Najd,
there might be some more information on that error in the Eclipse error log.
Have you checked that? It seems that your contributor cannot bne created.
Michael
Previous Topic:Drill down on a given node
Next Topic:Synchronize of cetaed elements with property view
Current Time: Tue May 28 14:18:02 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
