Home » Modeling » Graphiti » Drill down on a given node
Drill down on a given node [message #1059293] Thu, 16 May 2013 10:09 Go to next message
Hugo A. Garcia is currently offline Hugo A. Garcia
I would like to know if there are examples out there on how to do drill
down in a graph.
use case:
Our domain model is a hierarchical graph.
Given a node in a graph, the user double clicks on the node or uses a
context menu to drill down into the node.The result of the action should
ideally be to "zoom" into the node in the same window where only the
contents of the node would be visible in the graph window. Another
possible result of the action would be to open a new editor window with
only the content of the selected node shown.
-H
Re: Drill down on a given node [message #1059309 is a reply to message #1059293] Fri, 17 May 2013 09:31 Go to previous message
Marek Jagielski is currently offline Marek Jagielski
For your second results I do simple:
		Display.getCurrent().asyncExec(new Runnable() {
			public void run() {
				IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
				try {
					IDE.openEditor(page, (IFile) ifile, true);
				} catch (PartInitException e) {
in MyDoubleClickFeature. However every node of hierarchy is stored in separated diagram file which is no convenient in every use case.
Marek
Previous Topic:Compartment Rectangle
Next Topic:Property View - Unhandled event loop exception
Current Time: Tue May 28 14:18:35 EDT 2013
Powered by FUDForum. Page generated in 0.10371 seconds
