Home » Modeling » OCL » Why helper.createQuery() takes a considerable time?
Why helper.createQuery() takes a considerable time? [message #1058459] Tue, 14 May 2013 04:34 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Hi there,
I create an OCL query and execute that over an EObject called Device.
Sample code:
// create OCL instance for Ecore
OCL ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
// create OCL helper
OCLHelper<EClassifier, EOperation, EStructuralFeature, Constraint> helper = ocl
.createOCLHelper();
// set OCL context classifier
helper.setContext(ModelPackage.Literals.DEVICE);
// helper.setInstanceContext(ModelPackage.Literals.DEVICE__MODULES);
helper.setInstanceContext(device);
// create query
OCLExpression<EClassifier> query = helper
.createQuery("self.Modules->select(m|m.number<>null)->size()");
// use the query expression parsed before to create a Query
Query eval = ocl.createQuery(query);
int result = (Integer) eval.evaluate(device);
This is working fine, but createQuery() statement takes a considerable time. Any approach to fix that issue?
Here is my XML model:
<Device xmlns="model" xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" name="dd" comment="">
<HeadModule orderNumber="328061"/>
<Modules xsi:type="Module" number="1" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="2" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="3" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="4" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="5" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="6" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="7" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="8" deviceType="49157" orderNumber="328095"/>
<Modules xsi:type="Module" number="9" deviceType="15" orderNumber="328301"/>
<Modules xsi:type="Module" number="10" deviceType="15" orderNumber="328301"/>
<Modules xsi:type="NullModule" number="11"/>
<Modules xsi:type="NullModule" number="12"/>
<BackPlanes orderNumber="321702"/>
</Device>
Thanks in advance.
Kosala
[Updated on: Tue, 14 May 2013 05:10]
Report message to a moderator
Re: Why helper.createQuery() takes a considerable time? [message #1058482 is a reply to message #1058459] Tue, 14 May 2013 06:44 Go to previous messageGo to next message
It takes about 20 seconds to create an OCL expression or OCL constraint.
Is there any configuration setting missing in the above code?
Any help/opinion is appreciated.
Thanks in advance,
K
[Updated on: Tue, 14 May 2013 06:45]
Re: Why helper.createQuery() takes a considerable time? [message #1059016 is a reply to message #1058482] Thu, 16 May 2013 04:52 Go to previous messageGo to next message
Sorry, I still could not figure out the reason for the above issue.
I made ocl.setParseTracingEnabled(true).
Tracing results are:
[OCL] variableExpCS: Variable Expression: self
[OCL] variableExpCS: Property: Modules
[OCL] operationCallExpCS: size
12
false
It eats time, to come to the following step.
Anyone has a solution?
Kosala
[Updated on: Thu, 16 May 2013 05:18]
Re: Why helper.createQuery() takes a considerable time? [message #1059210 is a reply to message #1059016] Fri, 17 May 2013 06:17 Go to previous message
Updating the eclipse PDE class path with all dependent jars solved the problem.
Re: Why helper.createQuery() takes a considerable time? [message #1059251 is a reply to message #1058482] Wed, 15 May 2013 06:39 Go to previous message
The LPG-based parser is pretty quick; I would expect to see much less
than a second, except if starting a new VM.
The Xtext-based parser is slower but the CG tests that also start a Java
compiler take less than a second so a minute is clearly wrong.
I suspect that a missing registration is causing you to try top access
nsURIs over the Internet where a corporate firewall may make a slow
failure really slow.
I suggest using Wireshark to check what Internet accesses you are making.
Ed Willink
On 14/05/2013 11:44, Kosala Yapa wrote:
> It takes about 1 minute to create an OCL expression or OCL constraint.
> Thanks in advance,
> K
Re: Why helper.createQuery() takes a considerable time? [message #1059252 is a reply to message #1059016] Thu, 16 May 2013 05:13 Go to previous message
Read the answer on the EMF newsgroup.
> Cheers,
> Kosala
Previous Topic:How to read an OCL query and pass to an OCLExpression ?
Next Topic:line1 : error missing EOF at '('
Current Time: Tue May 28 16:16:15 EDT 2013
Powered by FUDForum. Page generated in 0.02213 seconds
