Home » Modeling » ATL » injection of an XMI into a database
injection of an XMI into a database [message #1058569] Tue, 14 May 2013 09:34 Go to next message
samar sousou is currently offline samar sousou
Member
Hi every body,
I need to know how can i do the injection of the XMI into a database!
thank you.
Re: injection of an XMI into a database [message #1058617 is a reply to message #1058569] Tue, 14 May 2013 10:47 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
This is a general EMF feature, you should probably take a look to the corresponding CDO project.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: injection of an XMI into a database [message #1058657 is a reply to message #1058617] Tue, 14 May 2013 11:40 Go to previous messageGo to next message
Member
Thank you Mr Hugo,
but i don't understand you.
I have an xmi as a result of the transformation and i want to inject it into a MySQL.
That's it.
can you explain me how to do.
thank you.
Samar.
Re: injection of an XMI into a database [message #1058668 is a reply to message #1058657] Tue, 14 May 2013 12:16 Go to previous messageGo to next message
The way you serialize/save your models is not directly related to ATL.
You should take a look to the CDO project that provides the relevant features to load/save EMF models from/into databases.
Nantes - France
Re: injection of an XMI into a database [message #1058825 is a reply to message #1058668] Wed, 15 May 2013 05:41 Go to previous messageGo to next message
Member
hi,
I want to know if i can do the transformation from my M2 to sql!!
if there is a solution, help me please.
thank you,
Samar.
Re: injection of an XMI into a database [message #1058857 is a reply to message #1058825] Wed, 15 May 2013 08:29 Go to previous messageGo to next message
If you want to produce an SQL file then this is another story.
Here are the consecutive steps to be performed:
  • Implement a Relational/SQL metamodel in Ecore;
  • Implement a YourMetamodel-to-Relational transformation in ATL (cf. the Class-to-Relational transformation example as an illustration);
  • Implement a Relational/SQL code generator using a Model-To-Text technology such as Acceleo for instance.
I hope this helps.
Hugo
Nantes - France
Re: injection of an XMI into a database [message #1058862 is a reply to message #1058857] Wed, 15 May 2013 08:59 Go to previous messageGo to next message
Member
Thank you Mr Hugo,
This is my purpose. and after i want to inject it into a DataBase.
Can you help me with a good tuto for the acceleo.
thank you.
Samar
[Updated on: Wed, 15 May 2013 09:35]
Report message to a moderator
Re: injection of an XMI into a database [message #1058905 is a reply to message #1058862] Wed, 15 May 2013 12:32 Go to previous messageGo to next message
All you need is available from the Acceleo website.
Nantes - France
Re: injection of an XMI into a database [message #1059197 is a reply to message #1058905] Fri, 17 May 2013 05:02 Go to previous messageGo to next message
Member
Hi Mr Hugo,
I did'nt understand how can i extract the data(instnace) from my model to the text.
because when i run I have no option to enter my model.
help me please,
samar.
Re: injection of an XMI into a database [message #1059204 is a reply to message #1059197] Fri, 17 May 2013 05:41 Go to previous message
This is a Model-to-Text issue so you should better ask your question onto the dedicated Eclipse forum (tagging your post with [Acceleo]).
Nantes - France
Previous Topic:How to use custom resource factory in the ATL Debug Launch Configuration
Next Topic:ATL
Current Time: Tue May 28 09:25:00 EDT 2013
Powered by FUDForum. Page generated in 0.01886 seconds
