| Split combined cells in a crosstab [message #1058900] |
Wed, 15 May 2013 11:32  |
Ivy Delaware Messages: 2 Registered: May 2013 |
Junior Member |
When I have a crosstab the cells that contain the same value are merged/ combined automatically.
It looks nice but when I export it in Excel and then want to filter/sort the columns Excel does not allow me to do so as the cells are merged.
Thus, I am looking for a way that the cells are NOT merged in the BIRT crosstab.
Is there any solution?
e.g.
2013 |2012
05|04|03|02|01|12|11|10|09|08|...
should be
2013|2013|2013|2013|2013|2012|2012|2012|2012|2012|...
05 |04 |03 |02 |01 |12 |11 |10 |09 |08 |...
| Re: Split combined cells in a crosstab [message #1059155 is a reply to message #1058900] |
Thu, 16 May 2013 23:38  |
Take a look at this. I wrote a computed column to give the first day of the month of the date field, then created two cubes with the dataSet. One of them uses the original date field with Year and Month selected for the grouping options. The other uses the computed column. I use the field twice to replicate what your example looked like and formatted the top as the year and the bottom as the month. Finally, I named both crosstabs, so that in the beforeFactory, I could check the output format and drop the appropriate crosstab from the report and switch the layout preference to auto for XLS as well.
Hope this helps.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
FUDForum. Page generated in 0.01590 seconds
