| Changing KDM programatically [message #1059078] |
Thu, 16 May 2013 10:44  |
Rafael Durelli Messages: 35 Registered: September 2012 |
Member |
Hello everyone I would like to know if it is possible to change the KDM programmatically. I mean, I have an instance of the KDM, which correspond a project in Java, then I would like to for instance "remove" a StorableUnit (a variable instance) to another ClassUnit, change the name of the ClassUnit, change the it from "public" to "private", and even create a MethodUnit programatically. Is that possible, if so, what should I use..
THanks in advance.
| Re: Changing KDM programatically [message #1059089 is a reply to message #1059078] |
Thu, 16 May 2013 11:23  |
Hugo Bruneliere Messages: 470 Registered: July 2009 |
The Ecore implementation of KDM provided by MoDisco comes with the corresponding EMF-generated API (also in the same plugin).
Using this API, you will be able to handle (and modify) your KDM model programmatically while loaded in memory.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
FUDForum. Page generated in 0.01647 seconds
