Home » Modeling » GMF (Graphical Modeling Framework) » Modify the origin of links
Modify the origin of links [message #1058243] Mon, 13 May 2013 06:34 Go to next message
Mårten Carlzon is currently offline Mårten Carlzon
Member
Hi all
I was wondering if it is possible to make a link go to the parent of a node instead of the node itself?
The setup I have is as follows:
RootNode -> ObjectData -> Attribute
The Attribute have a reference link to existing attribute that it inherits data from and I was wondering if I could make this linking go to the parent node.
Why I ask this is because I am using Eugenia and have the data as a compartment and when I minimize the Attribute node the linking hides as well and I would like to be able to show the links even when I minimize the node, either by moving the link to the parent or just keep showing the link upon minimization.
So in short:
Can I make a link go from parent to target instead of child to target?
And/Or can I make a link from a child be visible even if I minimize the child?
(I asked this in the Eugenia thread but they thought it might be a bit low-level so they pointed me here Smile)
Thanks for any help
Write you later / Mårten
Re: Modify the origin of links [message #1058982 is a reply to message #1058243] Thu, 16 May 2013 02:50 Go to previous message
Ralph Gerbig is currently offline Ralph Gerbig
this should help you
http://publib.boulder.ibm.com/infocenter/rsahelp/v7r0m0/index.jsp?topic=/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/diagram/core/commands/SetConnectionEndsCommand.html
http://publib.boulder.ibm.com/infocenter/rsahelp/v7r0m0/index.jsp?topic=/org.eclipse.gmf.doc/reference/api/runtime/org/eclipse/gmf/runtime/diagram/core/commands/SetConnectionAnchorsCommand.html
Ralph
Previous Topic:SETTING-UP the EDITOR Models by code
Next Topic:How to add Collapse All / Expand All menu option in GMF
Current Time: Tue May 28 13:36:49 EDT 2013
Powered by FUDForum. Page generated in 0.01660 seconds
