Home » Modeling » TMF (Xtext) » Standalone error when validating
Standalone error when validating [message #1058823] Wed, 15 May 2013 09:26 Go to next message
Mårten Carlzon is currently offline Mårten CarlzonFriend
Member
Hello all,
I was wondering if you could help me with an error I have when I generate a standalone generator for my XText project.
I am working on a XText Eugenia project that in the end turns my dsl code into xml code, so I wanted a runnable jar that only did the xml part but when I run that jar I get the following error:
------------------------ERROR MESSAGE---------------------------------------------
1 [main] ERROR xt.validation.ResourceValidatorImpl - The string resource '_UI_DiagnosticRoot_diagnostic' could n
ot be located
java.util.MissingResourceException: The string resource '_UI_DiagnosticRoot_diagnostic' could not be located
at org.eclipse.emf.common.util.DelegatingResourceLocator.delegatedGetString(DelegatingResourceLocator.java:4
80)
at org.eclipse.emf.common.util.DelegatingResourceLocator.getString(DelegatingResourceLocator.java:385)
at org.eclipse.emf.common.util.DelegatingResourceLocator.getString(DelegatingResourceLocator.java:499)
at org.eclipse.emf.common.util.DelegatingResourceLocator.getString(DelegatingResourceLocator.java:491)
at org.eclipse.emf.ecore.util.Diagnostician.createDefaultDiagnostic(Diagnostician.java:88)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:117)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:140)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:118)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:98)
at idainfront.iipax.dsl.main.Generator.runGenerator(Generator.java:42)
at idainfront.iipax.dsl.main.Main.main(Main.java:32)
Code generation finished.
The thing is my XML is generated correctly and the validation notices if something is wrong its just that the error message can be annoying to watch. So I was wondering if there is something I can do in my project to solve this? I have seen some solutions meddling with the jar after it is generated but I am supposed to hand over the project I am working on to others and I wanted to make it as self-going (and clean Smile) as possible.
Thanks for any help
Write you later / Mårten
Re: Standalone error when validating [message #1058824 is a reply to message #1058823] Wed, 15 May 2013 09:31 Go to previous messageGo to next message
Dennis Huebner is currently offline Dennis HuebnerFriend
You need a plugin.properties file on you class path/your jar root
<echo file="${binJarTemp}/plugin.properties">_UI_DiagnosticRoot_diagnostic=_UI_DiagnosticRoot_diagnostic</echo>
+Dennis Huebner
Get professional support from the Xtext committers at www.typefox.io
Re: Standalone error when validating [message #1058826 is a reply to message #1058824] Wed, 15 May 2013 09:51 Go to previous messageGo to next message
Member
Hmm... just asking... but how do I do that? Smile
I tried a few things but the closes I think I did was I added a file "plugin.properties" with the line you posted in the project, right-clicked the main file and took Run As -> Run Configurations, went to class path, user entries and added the file.
Did I miss something or do I just don't know what I am doing? Smile
Don't know if it is important but when I got many warnings when generating the jar file and one of them where "duplicate entry: plugin.properties".
Re: Standalone error when validating [message #1058828 is a reply to message #1058826] Wed, 15 May 2013 10:03 Go to previous messageGo to next message
How is your "runnable jar" created?
However, the story is the following:
emf.common needs a plugin.properties file which contains a following entry:
if you start mix contents of some bundles you overwrite same named files like e.g. plugin.properties or plugin.xml
+Dennis Huebner
Re: Standalone error when validating [message #1058830 is a reply to message #1058828] Wed, 15 May 2013 10:09 Go to previous messageGo to next message
Member
I create it with the export function in eclipse with the "Extract required libraries into generated JAR" option selected and I get tons of duplicate entries warnings.
Entire list
I have placed the main file in a different project which is dependent on my XText dsl project, maybe that is the cause for the duplication issues and I should just throw it right into the same project?
Hmm, feels strange to have a library that requires a file with only one line that seems to me to say that blue=blue Smile
[Updated on: Wed, 15 May 2013 10:11]
Report message to a moderator
Re: Standalone error when validating [message #1058832 is a reply to message #1058830] Wed, 15 May 2013 10:20 Go to previous messageGo to next message
You will probably need something more flexible e.g. ant?
It's just a dummy entry.
Take a look at org.eclipse.xtend.standalone.jar it contains most of the stuff you need. An ant script which creates this jar maybe also interesting:
http://git.eclipse.org/c/tmf/org.eclipse.xtext.git/tree/plugins/org.eclipse.xtend.standalone.maven/create-uberjar.ant
+Dennis Huebner
Re: Standalone error when validating [message #1058836 is a reply to message #1058832] Wed, 15 May 2013 10:55 Go to previous message
Member
Ok, I havent used ant before, been meddling a bit with maven which I think do similar things Smile
But I will look around and see if I can learn how this script works.
As long as I don't run the worflow file I am happy since it will remove my Eugenia code which made me try to step away from the maven script I had found Smile.
But thanks for all the feedback, now to learn and understand it.
Have a nice day.
Previous Topic:Single quotation marks consumed incorrectly
Next Topic:A Rule with a list of rules where all entrys are allowed once
Current Time: Sat Jul 22 09:03:14 GMT 2017
Powered by FUDForum. Page generated in 0.02137 seconds
