Home » Modeling » Epsilon » EuGENia Annotations
EuGENia Annotations [message #1058454] Tue, 14 May 2013 04:08 Go to next message
serhat gezgin is currently offline serhat gezgin
Hi all,
I need the non containment referance must be seen as node but i cant do this.
my sample meta-model is;
abstract class Field extends ContentUnit {
  attr boolean[1] required;
@gmf.node(label="name", figure="rectangle", label.icon="false", label.pattern="{0} :' Text'", label.edit.pattern="{0}")
class TextField extends Field {
  attr int displaySize;
  attr int maxLength;
@gmf.node(label="name")
class ContentType extends ContentUnit {
  attr String group;
  @gmf.compartment(layout="list", collapsible="false")
  ref Field[*] field;
I just need the non containment references seen as node (list compartment) on its parent comparment
(gmf.compartment (for non-containment EReference))
How can i do this ? Anyone can help me ?
[Updated on: Tue, 14 May 2013 06:29]
Report message to a moderator
Re: EuGENia Annotations [message #1058756 is a reply to message #1058454] Tue, 14 May 2013 18:29 Go to previous message
Dimitris Kolovos is currently offline Dimitris Kolovos
I'm afraid that non-containment references cannot be used to back GMF compartments - but I could be wrong.
Dimitris
Previous Topic:Node Label Pattern Configuration
Next Topic: EVL constraints dont work
Current Time: Tue May 28 12:38:26 EDT 2013
Powered by FUDForum. Page generated in 0.01697 seconds
