| (MAC) Program "g++" not found in PATH [message #1002986] |
Sat, 19 January 2013 21:00  |
Jack Ferris Messages: 3 Registered: January 2013 |
Junior Member |
I downloaded Eclipse IDE for C/C++ Developers for Mac and am trying to run a C program. I am getting these two errors when I create a new C project.
Program "gcc" not found in PATH
I'm assuming this has something to do with the compiler? I am not sure how to set this up, so any help would be appreciated. Is there something I need to mess with in the preferences or something I need to install?
see picture
EDIT: I downloaded the command line tools for xcode and the two errors went away. But, now I am getting an error: "Launch failed. Binary not found."
EDIT: Problem solved.
Thank to Klaus_Mr:
"Did you build test.cpp within Eclipse? On the screen shot I miss some generated folders:
Press CTRL+B (or however this key is called on a Mac). After a successfully build you should see a folder "Debug" or "Release" in the Project Explorer view and a virtual Folder Binaries. Now right click on one of the binaries and select Run as > Local C/C++ Application.
Klaus"
[Updated on: Mon, 21 January 2013 16:55] Report message to a moderator
FUDForum. Page generated in 0.08492 seconds
