| Re: WebCrawler issue using with proxy SMILA 1.2 [message #1058476 is a reply to message #1058210] |
Tue, 14 May 2013 06:02  |
Andreas Weber Messages: 23 Registered: July 2009 |
Junior Member |
> On downloading the SMILA 1.2 code, making changes to
> webcrawler.properties to include proxyHost and proxyPort within the
> bundle observed that the change are not reflected in SMILA.application's
> webcrawler.properties.
> The proxy changes had to be inside SMILA.application's
> webcrawler.properties for proxy setting.
General hint: Configuration changes always have to be done in SMILA's
"configuration" folder, not in the bundles directly.
When running SMILA in eclipse IDE, the configuration folder can be found
in the "SMILA.application" project.
> The port value is getting set to -1 in the current build and this is
> causing the target server not responding. On changing the value in
> UriHelper to have default of 80 the issue got resolved and am able to
> crawl http://wiki.eclipse.org/SMILA
After Andreas' fix, crawling with a proxy should be possible now without
code changes with the nightly build download (resp. current trunk when
running in eclipse IDE).
Andreas
FUDForum. Page generated in 0.02472 seconds
