Home » Modeling » ATL » code genetaion(code generation with ATL)
code genetaion [message #1050228] Fri, 26 April 2013 18:27 Go to next message
hadji ismail is currently offline hadji ismail
hello, i have question
Embarrassed is that can generate code with ATL? i means transformation model to code !!!
thank's for advence.
Re: code genetaion [message #1051789 is a reply to message #1050228] Mon, 29 April 2013 04:19 Go to previous messageGo to next message
Hugo Bruneliere is currently offline Hugo Bruneliere
ATL is principally a model-to-model transformation technology.
It is possible to write in text files using ATL queries.
However, if you really want to deal with extended code generation, I encourage you to use model-to-text technologies such as Eclipse Acceleo.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Re: code genetaion [message #1052977 is a reply to message #1051789] Wed, 01 May 2013 12:58 Go to previous messageGo to next message
However, if the distance between your model and code is non-trivial, you
should use one or more M2Ms such as ATL to get a text-like model so that
the M2T is easy.
ed Willink
On 29/04/2013 09:19, Hugo Bruneliere wrote:
> Hello,
> http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Language#ATL_Queries.
> http://www.eclipse.org/acceleo/.
> Hugo
Re: code genetaion [message #1053045 is a reply to message #1052977] Thu, 02 May 2013 04:00 Go to previous messageGo to next message
Thanks Ed for this perfect complementary information Smile
Hugo
Nantes - France
Re: code genetaion [message #1058406 is a reply to message #1053045] Mon, 13 May 2013 20:53 Go to previous message
france pope is currently offline france pope
great
Previous Topic:Generation of theTransformation in a java application
Next Topic:Refining mode: problems with drop feature
Current Time: Tue May 28 09:28:29 EDT 2013
Powered by FUDForum. Page generated in 0.04908 seconds
