| Re: [Import of uml file to model space] Not all Model elements imported [message #1057852 is a reply to message #1053415] |
Thu, 09 May 2013 06:27   |
Alexander Fülleborn Messages: 7 Registered: April 2013 |
Junior Member |
Hello Abel,
I believe that the VIATRA UML importer only works with UML 3.1 or less.
> In the Juno release of Eclipse, this is not offered in the "Install Software" area.
Also, the EMF importer and the UML importer are different things. You _can_ import UML models as EMF models, but you will have to first import the uml.ecore metamodels with the EMF metamodel importer.
Follow-up questions:
- do you have a "UML 2.2 importer" menu item in your model space -> native importers list?
> Yes, I have this menu item.
- do you have a "uml" entity in your model space, or is there only "nemf"?
> Yes, I have a "uml" entity in my model space.
I will ask our team members if anyone ported the UML importer to the 4.0 version (it requires the regeneration of a lot of code from the metamodel, and some manual changes to support profiles).
> Thanks. This would be great, of course. Do you already have an answer to this? What are your plans?
Kind regards, Alex
FUDForum. Page generated in 0.02775 seconds
