Home » Eclipse Projects » P2 » On a multi user setup, Is it possible to install a feature/plugin in the SHARED INSTALL AREA?(Multi User Eclipse setup (Installing new plugins))
On a multi user setup, Is it possible to install a feature/plugin in the SHARED INSTALL AREA? [message #1058371] Mon, 13 May 2013 14:26
Che Bumagat is currently offline Che Bumagat
Hi All -
Good day! I need your help guys.
I have an RCP application that is on a multi setup type of environment.
Based on this: http://help.eclipse.org/indigo/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fmulti_user_installs.html
So when a UserA installs addtional features/plugin it only comes available at his profile and so does UserB. Each having their own "configuration area" which I think is fine.
However, I'd like to know if it is also possible to install a feature/plugin that will be "common" to all users (e.g. Subclipse)? So that each user wouldn't have to install that plugin over again.
So instead of putting the feature under the "user configuration area" it will put it in the "shared install area"?
Appreciate your help!
[Updated on: Mon, 13 May 2013 14:27]
Report message to a moderator
Previous Topic:Is it Possible to Add New Features to the Shared Eclipse Install Area?
Current Time: Mon May 27 23:24:24 EDT 2013
Powered by FUDForum. Page generated in 0.06894 seconds
