Home » Modeling » Compare » Workspace Setup EMF Compare
Workspace Setup EMF Compare [message #1058001] Fri, 10 May 2013 08:40 Go to next message
Goood Guy is currently offline Goood Guy
Member
I want to import the EMF Compare plugins to my workspace. I followed the instructions on http://wiki.eclipse.org/EMF_Compare/Contributor_Guide, but I got many compile errors.
My target platform is Juno.
How can I import the plugins?
Re: Workspace Setup EMF Compare [message #1058198 is a reply to message #1058001] Mon, 13 May 2013 04:08 Go to previous messageGo to next message
Member
this is how I finally succeeded:
I checked out from 1.3. branch:
* o.e.e.c
* o.e.e.c.diff
* o.e.e.c.diff.edit
* o.e.e.c.epatch
* o.e.e.c.match
* o.e.e.c.ui
and created an API baseline.
Re: Workspace Setup EMF Compare [message #1058289 is a reply to message #1058198] Mon, 13 May 2013 09:18 Go to previous message
Laurent Goubet is currently offline Laurent Goubet
FYI, The baseline is not necessary. We use it to ensure API compatibility (or at least to document the evolutions), but that's not mandatory (and API errors are not compilation errors, i.e. they won't fail at runtime).
You can disable these particular errors in "Window > Preferences"; the configuration is located in the "Plug-in development > API baselines" section, where you need to set "missing API baseline" to "ignore" instead of the default "error".
Laurent Goubet
Obeo
[Updated on: Mon, 13 May 2013 09:18]
Report message to a moderator
Previous Topic:Changes in UML Model
Next Topic:org.eclipse.emf.compare singleton bundle?
Current Time: Tue May 28 10:16:32 EDT 2013
Powered by FUDForum. Page generated in 0.01483 seconds
