Home » Modeling » ATL » Generation of theTransformation in a java application
Generation of theTransformation in a java application [message #1058078] Fri, 10 May 2013 16:05 Go to next message
ransou RMG is currently offline ransou RMG
I would like to run the transformation of models in a Java application.I found this link:
http://www.eclipse.org/forums/index.php/m/632793/?srch=launch+transformation+from+java+file#msg_632793
which demonstrates the same example in ATL tutorial:Families2Persons.I don't know how to run it:is it in an ATL project or in a Java project?Is it enough to copy the code in the previous link and it runs successfully?And if it is in a java project how to solve the problem of the import of libraries related to org.eclipse.m2m.atl.
Please I really need to run the example in the link because if it runs with the example of Families2Persons it will run with any couple of metamodels(afder doing some modifications of course).
I will be grateful if you answer me as soon as possible.
Re: Generation of theTransformation in a java application [message #1058282 is a reply to message #1058078] Mon, 13 May 2013 08:59 Go to previous message
Hugo Bruneliere is currently offline Hugo Bruneliere
You should take a look to the ATL documentation section describing the ATL Core API.
You can also find from here a simple example showing how to launch an ATL transformation programmatically.
Hugo
Hugo Bruneliere - R&D Engineer
AtlanMod research team (Inria, EMN & LINA)
Ecole des Mines de Nantes
Nantes - France
Previous Topic:Using Coreservice to run ATL transformatin in java
Next Topic:code genetaion
Current Time: Tue May 28 09:28:51 EDT 2013
Powered by FUDForum. Page generated in 0.01459 seconds
