Home » Modeling » OCL » createQuery() takes a considerable time?
createQuery() takes a considerable time? [message #1058271] Mon, 13 May 2013 08:28
Kosala Yapa is currently offline Kosala Yapa
Hi there,
I create a OCL query and execute that over EObject.
Sample code:
// create OCL instance for Ecore
OCL ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
// create OCL helper
OCLHelper<EClassifier, EOperation, EStructuralFeature, Constraint> helper = ocl
.createOCLHelper();
// set OCL context classifier
helper.setContext(ModelPackage.Literals.DEVICE);
// helper.setInstanceContext(ModelPackage.Literals.DEVICE__MODULES);
helper.setInstanceContext(device);
// create query
OCLExpression<EClassifier> query = helper
.createQuery("self.Modules->select(m|m.number<>null)->size()");
// use the query expression parsed before to create a Query
Query eval = ocl.createQuery(query);
int result = (Integer) eval.evaluate(device);
This is working fine, but createQuery() statement takes a considerable time. Any approach to fix that issue?
Thanks in advance.
Kosala
Previous Topic:OCL to validate XML models?
Next Topic:How to execute OCL constraint?
Current Time: Tue May 28 16:17:21 EDT 2013
Powered by FUDForum. Page generated in 0.01876 seconds
