Home » Modeling » OCL » OCL to validate XML models?
OCL to validate XML models? [message #1057832] Thu, 09 May 2013 03:31 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Hi there,
I have model.ecore and model.xml and its codebase generated from model.genmodel. Now I need to find a way to write OCL rules and validate model.xml.
I like to keep OCL constraints separated from model.ecore.
Can someone propose me a good approach or tutorial?
Many thanks.
Yapa
[Updated on: Thu, 09 May 2013 04:38]
Report message to a moderator
Re: OCL to validate XML models? [message #1057840 is a reply to message #1057832] Thu, 09 May 2013 04:55 Go to previous messageGo to next message
Have you looked at the Eclipse OCL documentation where you will find two
tutorials?
Ed Willink
On 09/05/2013 08:31, Kosala Yapa wrote:
> Hi there,
> validate model.xml.
> Many thanks.
> Yapa
Re: OCL to validate XML models? [message #1057847 is a reply to message #1057840] Thu, 09 May 2013 05:57 Go to previous messageGo to next message
Hi Ed,
I did but could not find it is useful in my case.
I need to keep OCL constraints separated from ecore model, read them and validate against xml model.
Kosala
Re: OCL to validate XML models? [message #1057857 is a reply to message #1057847] Thu, 09 May 2013 07:21 Go to previous messageGo to next message
So read the Complete OCL tutorial
Ed Willink
On 09/05/2013 10:57, Kosala Yapa wrote:
> Hi Ed,
> Kosala
Re: OCL to validate XML models? [message #1058258 is a reply to message #1057857] Mon, 13 May 2013 07:51 Go to previous messageGo to next message
Thanks.
Now I have
// create OCL instance for ecore
OCL ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
// create OCL helper
OCLHelper<EClassifier, EOperation, EStructuralFeature, Constraint> helper = ocl
.createOCLHelper();
// set OCL context classifier
helper.setContext(ModelPackage.Literals.DEVICE);
//set device EObject
helper.setInstanceContext(device);
//create query expression
OCLExpression<EClassifier> query = helper
.createQuery("self.Modules->forAll(m|m.number<>null)->asSet()->size()");
Now the issue is, How to execute this query?
Any help is appreciated.
Yapa
Re: OCL to validate XML models? [message #1058267 is a reply to message #1058258] Mon, 13 May 2013 08:21 Go to previous message
Thanks. I could get that working. Complete code is:
// create OCL instance for Ecore
.createOCLHelper();
// helper.setInstanceContext(ModelPackage.Literals.DEVICE__MODULES);
// create query
.createQuery("self.Modules->select(m|m.number<>null)->size()");
// use the query expression parsed before to create a Query
Query eval = ocl.createQuery(query);
int result = (Integer) eval.evaluate(device);
System.out.println(result);
However this has a small problem, which is creating query takes a considerable time.
Any fix for that?
Kosala
Previous Topic:Problems with nested exists
Next Topic:createQuery() takes a considerable time?
Current Time: Tue May 28 16:17:43 EDT 2013
Powered by FUDForum. Page generated in 0.01596 seconds
