Home » Modeling » M2T (model-to-text transformation) » [Acceleo] How to iterate through the global UML model from inside a template
[Acceleo] How to iterate through the global UML model from inside a template [message #1051528] Sun, 28 April 2013 19:26 Go to next message
Spider 3000 is currently offline Spider 3000
Hi!
I have a simple starting template, like this:
[template public main(aClass : Class)]
[comment @main/]
[aClass.generate()/]
[/template]
Now in the method generate() I want to also iterate through all the objects of the type "Comment" (and not just the ones linked to aClass). How would I do that?
Thank you very much for any help!
[Updated on: Mon, 29 April 2013 19:24]
Report message to a moderator
Re: [Acceleo] How to iterate through the global UML model from inside a template question [message #1052184 is a reply to message #1051528] Mon, 29 April 2013 15:01 Go to previous messageGo to next message
That's what allInstances() allows you to do, if you're foolish enough
not to identify a much much more efficient algorithm.
Ed Willink
On 29/04/2013 03:53, Spider 3000 wrote:
> Hi!
> [comment @main/]
> [/template]
> Thanks you very much for any help!
Re: [Acceleo] How to iterate through the global UML model from inside a template question [message #1053421 is a reply to message #1052184] Sun, 05 May 2013 06:17 Go to previous messageGo to next message
Mathias Colpaert is currently offline Mathias Colpaert
Another classy reply from Ed.
Re: [Acceleo] How to iterate through the global UML model from inside a template question [message #1058264 is a reply to message #1053421] Mon, 13 May 2013 08:14 Go to previous message
Stephane Begaudeau is currently offline Stephane Begaudeau
If you want to iterate on all the elements with the type Comment in your UML model, you can do something like this:
[template public main (aModel : Model)]
[comment @main/]
[for (aComment : Comment | aModel.eAllContents(Comment))]
// do something
[/for]
[/template]
You should use the root of the UML model (Model) as the entry point of your generator instead of class. If you really need to start from a class, you can use something like:
[myClass.ancestors(Model)->first()/]
You can find an Acceleo-based UML to Java generator on Github if you want to have a look at a complex Acceleo generator (it is open source). You can find some information about this generator on my blog here and there.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Previous Topic:M2T with Xtext2 and Xtend2
Next Topic: [acceleo] How to create file "Android Model" with EMF Eclipse
Current Time: Tue May 28 14:51:54 EDT 2013
Powered by FUDForum. Page generated in 0.02401 seconds
