Home » Modeling » Epsilon » Question about adjusting links
Question about adjusting links [message #1058196] Mon, 13 May 2013 03:54 Go to next message
Mårten Carlzon is currently offline Mårten Carlzon
Member
Hi all
I have a few questions about links and their settings.
Is it possible to make a link go from its parent node instead of itself?
And/Or is it possible to make compartments in the emf file show links even if they are minimized?
My situation is that I have the following setup for nodes:
RootNode (has compartment) Object (has compartment) Attribute
The Attribute contains a reference to an attribute it inherits settings from and I was wondering if it would be possible to move that link up to RootNode or at least keep it visible if you minimize Attribute or Object?
Been fiddeling around in the emf file but setting source="parent" didn't work Smile
Have a nice day
Thanks for any help
Write you later / Mårten
Re: Question about adjusting links [message #1058241 is a reply to message #1058196] Mon, 13 May 2013 06:26 Go to previous messageGo to next message
Dimitris Kolovos is currently offline Dimitris Kolovos
Hi Mårten,
This sounds fairly low-level so I think that your best bet would be to investigate whether/how this is can be done by modifying the generated code. Perhaps someone over at the GMF forum can provide more hints on how you could go about this.
Dimitris
Re: Question about adjusting links [message #1058242 is a reply to message #1058241] Mon, 13 May 2013 06:28 Go to previous message
Member
Hi Dimitris
Ahh ok, will ask them over there and see if they know anything.
Will probably post here what the answer is for future reference.
Previous Topic:ETL equivalents performance
Next Topic:Node Label Pattern Configuration
Current Time: Tue May 28 12:39:22 EDT 2013
Powered by FUDForum. Page generated in 0.02092 seconds
