| Line wrapping but without inserting characters [message #1058216] |
Mon, 13 May 2013 05:10 |
Yugi Muto Messages: 28 Registered: February 2012 |
Junior Member |
I would like the Eclipse Java Editor (and Text Editor if it is possible) does line wrapping but without inserting characters.
I explain: You can already do line wrapping in Window > Preferences > Java > Code Style > Formatter > Edit... > Line Wrapping and select "Wrap where necessary".
But it inserts the break lines characters directly in the code when applying it with Ctrl + Shift + F.
What I would like is just an automatic line wrapping when the line is too long to be sure to see all the file content without necessary to use the horizontal scroll-bar.
Some well known editors have this feature:
- Vim
- The Windows notepad (using Format > Word Wrap)
Is there the same feature on Eclipse ?
Thank you.
Regards.
[Updated on: Mon, 13 May 2013 05:12] Report message to a moderator
FUDForum. Page generated in 0.01513 seconds
