Home » Modeling » OCL » Problems with nested exists
Problems with nested exists [message #1058139] Sun, 12 May 2013 08:41 Go to next message
Bernhard Berger is currently offline Bernhard Berger
I have some trouble with some OCL expressions I want to evaluate using Pivot. For writing the expressions I am using the Xtext OCL console and I am ending up with a "Evaluation failure" I do not understand.
The problem -as far as I reduced it- originates from two nested exists where the inner tries to access the variable of the outer exists. Starting from an arbitrary ecore file I open the "Xtext OCL console" for a class with some attributes (for instance the Book class in extlibrary example) then I enter the following expression:
eStructuralFeatures->exists(feature | Set{true}->exists(data | feature.name = ''))
The interpreter then prints:
Evaluation failure
Invalid source for '='
The = is not related to the = in the expression. I'm aware that the code is semantically useless but the original query is longer.
The "Interactice OCL console" returns a boolean value instead of throwing an error. Is it a bug in the Xtext OCL console
Thanks in advance and regards,
Bernhard
Re: Problems with nested exists [message #1058143 is a reply to message #1058139] Sun, 12 May 2013 09:55 Go to previous message
Thanks. https://bugs.eclipse.org/bugs/show_bug.cgi?id=407817 raised.
The current code returns
'NavigableObject' rather than 'Boolean' value required
presumably because the inner 'feature' reference has been resolved to
the Boolean inner 'data' rather than the Object outer 'feature'.
Ed Willink
On 12/05/2013 13:41, Bernhard Berger wrote:
> feature.name = ''))
> Evaluation failure
> Bernhard
Previous Topic:[OCLinEcore][bug?] @pre tag and isPre() method not working properly
Next Topic:OCL to validate XML models?
Current Time: Tue May 28 16:18:17 EDT 2013
Powered by FUDForum. Page generated in 0.01741 seconds
