Home » Language IDEs » Java Development Tools (JDT) » Java buildpath can't support .jpp file?
Java buildpath can't support .jpp file? [message #1057973] Fri, 10 May 2013 05:13 Go to next message
cernis tang is currently offline cernis tang
I tried to add some jpp file into build path, but it seems it doesn't support.
the .jpp files will be preprocessed and generated into .java file, but I want to add .jpp files into eclipse project.
Re: Java buildpath can't support .jpp file? [message #1057999 is a reply to message #1057973] Fri, 10 May 2013 08:29 Go to previous message
Ed Merks is currently offline Ed Merks
Generally you add folders to the classpath (build path). Is that what
you did?
> support.
Previous Topic:Problem to install windows builder on juno
Next Topic:Jsp + servlet plugins for Helios
Current Time: Tue May 28 06:21:49 EDT 2013
Powered by FUDForum. Page generated in 0.01748 seconds
