Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » Cannot install MTJ on Juno
| Cannot install MTJ on Juno [message #986034] |
Sat, 17 November 2012 14:13  |
Dave Donald Messages: 26 Registered: January 2012 |
Junior Member |
As title.
I went to "install new software"
in the work with I selected "http://download.eclipse.org/releases/indigo/201106220900"
than I select mobile tools for java, mobile tools for java examples and mobile tools for java SDK and I get this error.
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,antenna.preprocessor.v3,1.3.0.201106060709
No repository found containing: osgi.bundle,de.schlichtherle.truezip,6.6.0.201106060709
No repository found containing: osgi.bundle,javax.servlet,2.5.0.v201103041518
No repository found containing: osgi.bundle,jmunit.framework,1.2.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.branding,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.core,1.2.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.core.hooks,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.core.hooks.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.core.source,1.2.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.doc.isv,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.doc.user,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.eswt.templates,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.eswt.templates.source,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.example.library,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.example.library.source,1.0.0.201106060709
No repository found containing: org.eclipse.update.feature,org.eclipse.mtj.examples,1.1.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.jadextension,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.jadextension.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.templates,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.templates.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.toolkit.sdkprovidertestclamp,1.0.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.toolkit.sdkprovidertestclamp.source,1.0.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.toolkit.sdkprovidertestclamp2,1.0.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.toolkit.sdkprovidertestclamp2.source,1.0.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.toolkits,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.examples.toolkits.source,1.0.0.201106060709
No repository found containing: org.eclipse.update.feature,org.eclipse.mtj,1.1.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.jmunit,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.jmunit.source,1.0.1.201106060709
No repository found containing: org.eclipse.update.feature,org.eclipse.mtj.sdk,1.1.2.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.templates,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.templates.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.cinterion,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.cinterion.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.microemu,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.microemu.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.mpowerplayer,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.mpowerplayer.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.nokia,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.nokia.source,1.0.0.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.uei,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.toolkit.uei.source,1.0.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.ui,1.2.1.201106060709
No repository found containing: osgi.bundle,org.eclipse.mtj.ui.source,1.2.1.201106060709
No repository found containing: osgi.bundle,org.mortbay.jetty.server,6.1.23.v201012071420
No repository found containing: osgi.bundle,org.mortbay.jetty.util,6.1.23.v201012071420
Is MTJ dead? Is there any way to install it on Juno?
| Re: Cannot install MTJ on Juno [message #1057958 is a reply to message #1007442] |
Fri, 10 May 2013 03:08  |
cernis tang Messages: 2 Registered: May 2013 |
Junior Member |
Serban Var wrote on Tue, 05 February 2013 16:18If you read these release notes you will find the solution:
oracle.com/javame/dev-tools/jme-sdk-3.2/release-notes/pdf/release-notes.pdf
Install the MTJ toolkitand follow these steps:
a. Go to Help > Install New Software.
b. In the "Work with" field, enter this URL: http://download.eclipse.org/releases/indigo
c. Click Add. When the plugins are discovered, open the Mobile and Device Development Tools hierarchy and check Mobile Tools for Java Examples and Mobile Tools for Java SDK. Click Next.On the installation screen select all plugins and click Finish then click OK.
d. A Juno plugin named org.eclipse.jetty.server_.jar conflicts with the MTJ libraries when the plugin version is higher than 6. If it is you must prevent it from loading by changing its name so the Jar file is not parsed. Locate the file in your Juno installation's \plugins directory and change the extension from .jar to something else. For example, change it to: org.eclipse.jetty.server_.old
Even I dont' have the plugin org.eclipse.jetty.server_.jar, it still can't work.
Current Time: Mon May 27 22:43:35 EDT 2013
Powered by FUDForum. Page generated in 0.01877 seconds
