Home » General (non-technical) » Eclipse Foundation » Cannot open eclipse
Cannot open eclipse [message #1057778] Wed, 08 May 2013 12:44 Go to next message
macs capstone is currently offline macs capstone
Im using Eclipse Indigo on an Ubuntu 12.04 OS. I've been using it for a while now when a sudden power blackout happened and caused my eclipse to crash. When i tried to open it again, it would hang and not continue on start up. I found the log file but I cant understand what it says so I am seeking your help. Here is the latest log.
!SESSION 2013-05-08 23:00:40.296 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_24
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_PH
Command-line arguments:  -os linux -ws gtk -arch x86
!ENTRY org.eclipse.osgi 4 0 2013-05-08 23:00:42.797
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (50).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
	at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:473)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:616)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Caused by: java.lang.ArrayIndexOutOfBoundsException
	at java.lang.System.arraycopy(Native Method)
	at org.eclipse.core.internal.localstore.SafeChunkyInputStream.shiftAndFillBuffer(SafeChunkyInputStream.java:170)
	at org.eclipse.core.internal.localstore.SafeChunkyInputStream.find(SafeChunkyInputStream.java:94)
	at org.eclipse.core.internal.localstore.SafeChunkyInputStream.find(SafeChunkyInputStream.java:98)
	at org.eclipse.core.internal.localstore.SafeChunkyInputStream.buildChunk(SafeChunkyInputStream.java:56)
	at org.eclipse.core.internal.localstore.SafeChunkyInputStream.read(SafeChunkyInputStream.java:141)
	at java.io.InputStream.read(InputStream.java:179)
	at java.io.InputStream.read(InputStream.java:101)
	at java.util.Properties$LineReader.readLine(Properties.java:435)
	at java.util.Properties.load0(Properties.java:354)
	at java.util.Properties.load(Properties.java:342)
	at org.eclipse.core.internal.resources.SaveManager.restoreMasterTable(SaveManager.java:830)
	at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:685)
	at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1528)
	at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2503)
	at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2251)
	at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:439)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
	... 28 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2013-05-08 23:00:42.837
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (50).
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
	... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
	... 22 more
	... 28 more
Re: Cannot open eclipse [message #1057876 is a reply to message #1057778] Thu, 09 May 2013 09:40 Go to previous message
Eclipse User
This is the wrong forum. Please use the eclipse.platform forum.
Thank you.
Previous Topic:Stanford Eclipse Log Error! Please help?
Next Topic:No technical questions, please!
Current Time: Mon May 27 23:56:14 EDT 2013
Powered by FUDForum. Page generated in 0.01629 seconds
