| Eclipse PDT and XDebug 2.2.2 [message #1053000] |
Wed, 01 May 2013 16:30  |
I'm trying to configure eclipse PDT with xdebug, in order to be able to debug my PHP code i create for Joomla/Prestashop and other CMS.
i must say that tutorials i found till now are really old and they do not reflect the current situation in terms of options, versions or feature and settings.
i tried:
http://docs.joomla.org/Configuring_Eclipse_and_Xdebug
but i wasn't able to make it run properly..
in fact even if i have break points eclipse do not stop on them.
i check if i didn't do something stupid with xdebug and tried with another IDE like PHPStorm and it works well...
so something must be wrong with eclipse settings.
Could you tell me where can i find a new tutorials or necessary information to be able to setup it correctly ?
thx.
thx.
what does not kill you, makes you stronger
http://www.rogtek.com
http://www.facebook.com/rogtek
| Re: Eclipse PDT and XDebug 2.2.2 [message #1057787 is a reply to message #1053137] |
Wed, 08 May 2013 13:57  |
Testr t Messages: 18 Registered: April 2013 |
Junior Member |
Hi Roger,
I had the same issue and I still have the issue. I set up a WAMP server with some php files in it which are used as webservice rather than a web page. I tried to debug the script from browser but it never stops on the breakpoints,(I have the break at first line option and also have some breakpoints). I am able to debug as a php script though but it would be useful for me only if I can debug it when using from the browser. Can you let me know what you have changed to make the breakpoints work from the chrome browser?
FUDForum. Page generated in 0.01694 seconds
