Home » Eclipse Projects » DTP » Hide Connection profile in SQLScrapbookEditor?
Hide Connection profile in SQLScrapbookEditor? [message #1057086] Wed, 08 May 2013 08:15 Go to next message
David Balažic is currently offline David Balažic
The connection profile on the top of the SQL editor takes away precious (vertical) screen estate.
Is there a way to turn it off or hide it?
I use Eclipse Java EE IDE for Web Developers.
Version: Juno Service Release 2
Build id: 20130225-0426
David
Re: Hide Connection profile in SQLScrapbookEditor? [message #1057765 is a reply to message #1057086] Wed, 08 May 2013 11:47 Go to previous message
The forum has connections troubles (at least for me) today, that may be the cause of this thread appearing 6 times (I swear I pushed the Submit button only once). I ask the moderator to clean up the duplicate threads.
Previous Topic:Show Errors on Oracle PL/SQL compile?
Next Topic:Data Source Explorer Column list reverse order Java 7
Current Time: Wed May 29 04:20:07 EDT 2013
Powered by FUDForum. Page generated in 0.51768 seconds
