Home » Eclipse Projects » Test and Performance Tools Platform (TPTP) » Re: ClassCastException in GenModel if org.eclipse.xsd is present
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102290] Mon, 02 July 2007 12:35 Go to next message
Eclipse User
Nicolas,
I'll add the TPTP newsgroup to the reply to see if anyone there knows a
reason why TPTP would affect the parser created via the standard JAXP
APIs, i.e., why SAXParserFactory.newInstance() should fail with TPTP
present.
Nicolas Cabanis wrote:
> And I use:
> java version "1.6.0"
> Java(TM) SE Runtime Environment (build 1.6.0-b105)
> Java HotSpot(TM) Client VM (build 1.6.0-b105, mixed mode)
> Nicolas Cabanis schrieb:
>> Hell Ed,
>> I use:
>> - eclipse-SDK-3.3 (and all following through Europa update site)
>> - TPTP Tracing and Profiling
>> - TPTP Platform (4.3.0v200706132116...)
>> - XSD (2.3.0v20070626000)
>> All I do is open a .genmodel file. But TPTP may be activted as it is
>> included in all perspectives.
>> I have just tried to activate XSD without TPTP - and it all works.
>> Nicolas
>> Ed Merks schrieb:
>>> Nicolas,
>>> I tried this locally with a slightly pre-GA setup without a
>>> problem. Do I need to use something in TPTP first before the
>>> problem starts to happen? I.e., does the problem happen with a
>>> freshly started Eclipse where all you've done is tried to open a
>>> .genmodel file as your first action?
>>> Ed Merks wrote:
>>>> Nicolas,
>>>> Sounds like some other component has registered an JAXP
>>>> implementation that's in conflict with the one provided by the JVM
>>>> because the code that's failing is just this standard pattern that
>>>> should work anywhere:
>>>> SAXParserFactory parserFactory=
>>>> SAXParserFactory.newInstance();
>>>> I know that XSD doesn't register such a thing, but perhaps TPTP's
>>>> use of this plugin causes a problem:
>>>> eclipse/plugins/org.apache.xerces_2.8.0.v200705301630.jar
>>>> If that is indeed the problem, I imagine that many things relying
>>>> on JAXP to simply work will be broken. Which JVM/JRE are you using?
>>>>> Hello,
>>>>> I have updated my Eclipse to 3.3 final together with EMF, GEF and
>>>>> GMF. Now, I get the following problem: if I open any genmodel with
>>>>> the GenModel-Editor, I get the exception appended at the end of
>>>>> this message. This only happens if I have TPTP (and therefore XSD)
>>>>> also in my configuration.
>>>>> How can I prevent this?
>>>>> Regards
>>>>> Nicolas
>>>>> java.lang.ClassCastException:
>>>>> org.apache.xerces.jaxp.SAXParserFactoryImpl cannot be cast to
>>>>> javax.xml.parsers.SAXParserFactory
>>>>> at javax.xml.parsers.SAXParserFactory.newInstance(Unknown Source)
>>>>> at
>>>>> org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformPlug inToPlatformResourceMap(EcorePlugin.java:302)
>>>>> at
>>>>> org.eclipse.emf.ecore.plugin.EcorePlugin.computePlatformURIM ap(EcorePlugin.java:409)
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102344 is a reply to message #102290] Mon, 02 July 2007 15:26 Go to previous messageGo to next message
Joe Toomey is currently offline Joe Toomey
Member
It's worth noting that although some committers may do informal testing,
TPTP does not yet support Java 6.
http://www.eclipse.org/tptp/home/project_info/releaseinfo/4. 4/support.html
I can't comment on why we distribute the org.apache.xerces bundle, but I
see that we (TPTP) require and reexport it in
org.eclipse.tptp.platform.models. Neither the plugin.xml file nor the
java code within our models plugin references or uses the
org.apache.xerces plugin. I will check with the plugin owner to
understand why this is the case -- I have a foggy recollection of why we
used to continue to ship xerces, but my recollection may be out of date.
I tried the scenario described using Sun 1.5 & 1.6 and also tried with
an IBM 1.6 JRE. I wasn't able to reproduce this issue (the genmodel
editor opened fine, no errors reported in the log.) I also checked in
the OSGI console, and in each case, the org.apache.xerces plugin was
resolved but not active after opening the genmodel file.
[I'm using Europa bits from today -- Eclipse Classic Windows download,
then TPTP installed via Update Manager. Among the required plugins
selected by UM were "EMF Runtime + End-User Tools 2.3.0.v200706262000"
and "XSD Schema Infoset Model 2.3.0.v200706262000".]
Ed -- are you able to see this error?
--Joe
Ed Merks wrote:
> Nicolas,
> present.
>> And I use:
>>> Hell Ed,
>>> I use:
>>> Nicolas
>>> Ed Merks schrieb:
>>>> Nicolas,
>>>> Ed Merks wrote:
>>>>> Nicolas,
>>>>>> Hello,
>>>>>> Regards
>>>>>> Nicolas
>>>>>> at
>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102353 is a reply to message #102344] Mon, 02 July 2007 15:29 Go to previous messageGo to next message
Eclipse User
Joe,
No. I have some bits slightly older than the GA version and it's all
working fine for me. I've never heard of a problem like this before
either. It's quite a basic/fundamental thing that's going wrong...
> testing, TPTP does not yet support Java 6.
> I see that we (TPTP) require and reexport it in
> we used to continue to ship xerces, but my recollection may be out of
> date.
> --Joe
> Ed Merks wrote:
>> Nicolas,
>> a reason why TPTP would affect the parser created via the standard
>> JAXP APIs, i.e., why SAXParserFactory.newInstance() should fail with
>> TPTP present.
>>> And I use:
>>>> Hell Ed,
>>>> I use:
>>>> is included in all perspectives.
>>>> Nicolas
>>>> Ed Merks schrieb:
>>>>> Nicolas,
>>>>> Ed Merks wrote:
>>>>>> Nicolas,
>>>>>> JVM because the code that's failing is just this standard pattern
>>>>>> that should work anywhere:
>>>>>>> Hello,
>>>>>>> and GMF. Now, I get the following problem: if I open any
>>>>>>> genmodel with the GenModel-Editor, I get the exception appended
>>>>>>> at the end of this message. This only happens if I have TPTP
>>>>>>> (and therefore XSD) also in my configuration.
>>>>>>> Regards
>>>>>>> Nicolas
>>>>>>> at
>>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102377 is a reply to message #102353] Mon, 02 July 2007 16:26 Go to previous messageGo to next message
Member
Agreed. I'm not sure how/if we're involved, but if we can figure out
how to reproduce the problem, I'll be happy to investigate on the TPTP side.
--Joe
Ed Merks wrote:
> Joe,
>> date.
>> Thanks,
>> --Joe
>> Ed Merks wrote:
>>> Nicolas,
>>> TPTP present.
>>>> And I use:
>>>>> Hell Ed,
>>>>> I use:
>>>>> Nicolas
>>>>> Ed Merks schrieb:
>>>>>> Nicolas,
>>>>>> Ed Merks wrote:
>>>>>>> Nicolas,
>>>>>>>> Hello,
>>>>>>>> Regards
>>>>>>>> Nicolas
>>>>>>>> at
>>>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #102585 is a reply to message #102377] Tue, 03 July 2007 09:33 Go to previous messageGo to next message
Miles Parker is currently offline Miles Parker
As a btw, I think JAXP / Xerces related incompatabilites, especially
given their "fail-slow" nature, create painful issues in intergrating
various projects. The same kinds of things have come up w/ oAW, e.g.:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=186687
> side.
> --Joe
> Ed Merks wrote:
>> Joe,
I
>>> date.
>>> Thanks,
>>> --Joe
>>> Ed Merks wrote:
>>>> Nicolas,
>>>> present.
>>>>> And I use:
>>>>>> Hell Ed,
>>>>>> I use:
>>>>>> Nicolas
>>>>>> Ed Merks schrieb:
>>>>>>> Nicolas,
>>>>>>> I tried this locally with a slightly pre-GA setup without a problem.
>>>>>>> Do I need to use something in TPTP first before the problem starts to
>>>>>>> happen? I.e., does the problem happen with a freshly started Eclipse
>>>>>>> where all you've done is tried to open a .genmodel file as your first
>>>>>>> action?
>>>>>>> Ed Merks wrote:
>>>>>>>> Nicolas,
>>>>>>>> Sounds like some other component has registered an JAXP implementation
>>>>>>>> that's in conflict with the one provided by the JVM because the code
>>>>>>>> that's failing is just this standard pattern that should work anywhere:
>>>>>>>> SAXParserFactory parserFactory= SAXParserFactory.newInstance();
>>>>>>>> I know that XSD doesn't register such a thing, but perhaps TPTP's use
>>>>>>>> If that is indeed the problem, I imagine that many things relying on
>>>>>>>>> Hello,
>>>>>>>>> I have updated my Eclipse to 3.3 final together with EMF, GEF and GMF.
>>>>>>>>> Now, I get the following problem: if I open any genmodel with the
>>>>>>>>> GenModel-Editor, I get the exception appended at the end of this
>>>>>>>>> message. This only happens if I have TPTP (and therefore XSD) also in
>>>>>>>>> my configuration.
>>>>>>>>> Regards
>>>>>>>>> Nicolas
>>>>>>>>> at
>>>>>>>>> at
Re: ClassCastException in GenModel if org.eclipse.xsd is present [message #1056020 is a reply to message #102585] Wed, 08 May 2013 06:20 Go to previous message
arron lee is currently offline arron lee
Member
The guys are all nice here.
I am glad to see your problem has been solved.
What's more, I have found a solution of my problem dealing with PDF.
Thanks again.
Arron
I'm new at eclipse
Wanna learn more about dealing with http://www.yiigo.com/ and http://www.yiigo.com/net-document-image-plugin/ocr-plugin/.
I'm new at eclipse
Wanna learn more about dealing with images, barcodes, and documents and OCR.
Previous Topic:Memory analizer for secondary thread
Current Time: Mon May 27 23:45:00 EDT 2013
Powered by FUDForum. Page generated in 0.01820 seconds
