Home » Eclipse Projects » BPMN 2.0 Modeler » Put a Flag in elements of the BPMN
Put a Flag in elements of the BPMN [message #1053858] Tue, 07 May 2013 18:15 Go to next message
reg bas is currently offline reg bas
Hello! First I wanted to clarify that I'm not very good at English so I use Google Translator to translate this topic.
My question is whether there is the possibility, using plug-ins to place a flag in some of the elements of bpmn and add extra information elements containing this flag.
The example I gain CustomTask the case because it creates a different task to the other, and the idea is that this flag does not alter the basis of the elements that already exist in the palette, but this flag can be incorporated or it also can be removed.
Is this possible?
It would be a lot of work? I'm no expert in programming and less on development of plug-ins, only some basic things in java programming, but if possible to create a plugin with these features, I will endeavor!
In advance thank you very much Smile
Re: Put a Flag in elements of the BPMN [message #1053863 is a reply to message #1053858] Tue, 07 May 2013 20:14 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Hi and welcome to the forum!
As a first step, you should probably become familiar with how to create an eclipse plug-in. There are many resources available on the web but if you get stuck, please feel free to post your questions here.
A good place to start is with some of the example plug-ins. There is also a screencast of how to create a custom task here:
http://eclipse.org/bpmn2-modeler/videos/CustomTask-Example-part1.htm
Hope this helps.
Bob
Re: Put a Flag in elements of the BPMN [message #1053871 is a reply to message #1053863] Tue, 07 May 2013 23:22 Go to previous messageGo to next message
Thanks Robert for your answer, your willingness and welcome!
That example I've made ​​several times to understand what it does and how. The difference is that this example creates a new type of task, a custom one, I want to add to some of the elements that already exist, ideally a mark on the top of the icon show a brand, and adds that the element could also be removed.
By this I mean that could be either an ordinary task, as it could also be a task or a data user input. I mean that the brand should be an addition to the ones already used in the diagram and can be combined with some of elements represented by images.
My question is whether it would be possible, as I read in a previous topic that does not exist an API for BPMN and not what atachar the item without having to create one for task, one for data and so on.
It cost me a bit of myself understood, but I hope that the time spent answering not in vain.
Thank you very much!
Re: Put a Flag in elements of the BPMN [message #1056397 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Are you talking about adding "decorators" to a task shape, something like this?
http://content.screencast.com/users/rbrodt/folders/Jing/media/92284c2c-80d7-4003-94a2-6951660eea0e/2013-05-08_0536.png
or adding custom images to a task shape, like this?
http://content.screencast.com/users/rbrodt/folders/Jing/media/8af77e16-39f0-4f20-b219-22bdcd4a84d0/2013-05-08_0534.png
Re: Put a Flag in elements of the BPMN [message #1056398 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Are you talking about adding "decorators" to a shape like this?
or adding custom images to a shape like this?
Re: Put a Flag in elements of the BPMN [message #1056399 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Re: Put a Flag in elements of the BPMN [message #1056472 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Re: Put a Flag in elements of the BPMN [message #1056489 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Re: Put a Flag in elements of the BPMN [message #1056572 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056573 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056574 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056575 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056667 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056668 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056669 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056670 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056671 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056763 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056764 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056765 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056766 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056767 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056861 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056862 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056863 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056864 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056865 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056962 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056963 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056964 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056965 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1056966 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057065 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057066 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057067 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057068 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057069 is a reply to message #1053871] Wed, 08 May 2013 07:41 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057170 is a reply to message #1053871] Wed, 08 May 2013 07:37 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057171 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to next message
Member
Re: Put a Flag in elements of the BPMN [message #1057172 is a reply to message #1053871] Wed, 08 May 2013 07:39 Go to previous messageGo to previous message
Member
Previous Topic:Launch BPMN modeler plugin from source code
Next Topic:Example Custom Task screencast tutorial now available
Current Time: Tue May 28 23:20:02 EDT 2013
Powered by FUDForum. Page generated in 3.44858 seconds
