Home » Language IDEs » AJDT » AspectJ AOP config with JSP
AspectJ AOP config with JSP [message #1053662] Tue, 07 May 2013 04:05 Go to next message
Extreme Java is currently offline Extreme Java
I have configured AspectJ in my spring application. Since my app is a legacy app which is using JSP scriptlet code for server side processing.
The problem I am facing is that I want to invoke an @AfterThrowing Advice when an Exception occurs in the JSP scriptlet code.
My Advice method signature as of now is:
    @Aspect
    public class NotificationAdvice {
        @AfterThrowing(pointcut = "execution(* com.app.OtherBeanIntf.doSomething(..))", throwing = "error")
        public void logAfterThrowing(JoinPoint joinPoint, Throwable error) {
In the above code, OtherBeanIntf is another Java bean which is working fine with this logging advice. Now how do I configure this advice to work with JSP scriptlet code too?
Re: AspectJ AOP config with JSP [message #1053790 is a reply to message #1053662] Tue, 07 May 2013 11:33 Go to previous message
Andrew Eisenberg is currently offline Andrew Eisenberg
Since JSPs are compiled separately from java classes, there are different things you need to do to weave them. Here is a tutorial that describes something that might work: http://www.eclipse.org/aspectj/sample-code.html#j2ee-tomcat4-jsp (I haven't tried this myself).
Previous Topic:IllegalMonitorStateException using locks
Next Topic:ClassFormatException with AJDT and RAD 8
Current Time: Tue May 28 04:45:11 EDT 2013
Powered by FUDForum. Page generated in 0.08760 seconds
